-   -   Yj clutch problems (http://www.jeepforum.com/forum/f12/yj-clutch-problems-1530928/)
FUBAR86 06-01-2013 11:13 AM
Yj clutch problems
Ok so I have a 95 yj 4.0, the other day I was
Driving and noticed the clutch was acting different, I noticed because I stalled :(, but what I experienced or seams like what is going on is when I hold the pedal down for a long periods of time( such as reversing out a parking space) when I put it back in 1st it seams different. I guess the beat way I can diacribe it is, most the time the clutch disengages about a inch or two from the top of the pedal and with what I have been experiencing web holding the clutch down it seams to engage at the bottom of the pedal.. Witch is not normal. I had a clutch replaced about 3000 miles ago and have not had a problem untill the other day. If you have other questions I will be happy to try and answer them for you. Thanx in advance!
Mark05059 06-01-2013 12:49 PM
check the fluid level in your clutch master.
FUBAR86 06-01-2013 01:10 PM
Fluid was full. I already suspected the master cylinder was going bad because of some other stuff I had read. So I replaced it this morning and seams to have fixed the problem. Thank you for the reply..:cool:
The time now is 12:27 AM.
