YJ Clutch Help Please - JeepForum.com
post #1 of 4 Old 04-09-2013, 09:37 PM Thread Starter
Smorrow
I have a 93 yj. About 95% of the time when I drive, it shifts perfect. The other times what happens is when I come to a stop light and put it in neutral, when I try to put in back in 1st (or any gear), it won't go. I have to wiggle and force it until it finally goes in gear. If I roll to the stop light, I can put it in any gear as I am about two mph. Any suggestions? Thx
Smorrow is offline
post #2 of 4 Old 04-09-2013, 09:44 PM
Relicmoto
Sounds to me like the synchronizers are going out. Try draining and refilling the 10w-30 in your trans and look for any evidence of metal shards in the old oil. Refill not to waste oil, but to see if there is any improvement after you do it.
Relicmoto is offline
post #3 of 4 Old 04-09-2013, 10:33 PM
timatoe
timatoe's Avatar
Check the fluid level in you clutch master cylinder. I'll bet you find it's low.
timatoe is offline
post #4 of 4 Old 04-10-2013, 06:58 PM Thread Starter
Smorrow
So I checked the fluid. It was 2/3 full. I don't think that should cause this? Any other ideas?
Smorrow is offline
