YJ Clutch Adjustment? - JeepForum.com
post #1 of 15 Old 10-22-2012, 11:43 AM Thread Starter
qlfarm
My YJ is getting hard to shift and I think I need to adjust the clutch. First and second gear are becoming hard to go into and reverse is starting to grind if I don't have the pedal just right.
How do you adjust it on a 1990 with a 5 speed/4.2 6 cylinder?
Any help would be greatly appreciated.
qlfarm is offline
post #2 of 15 Old 10-22-2012, 01:33 PM
booboowv77
As far as i know there is no adjustment on the clutch. I would start with checking the fluid for the clutch and also change the fluid in the trans, and see if it gets better. If not post back.
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #3 of 15 Old 10-23-2012, 07:25 AM Thread Starter
qlfarm
Ok; where do I check the fluid for my clutch?
The pedal feels funny; I think I have more travel than I should before the clutch engages.
It is worse on cold mornings.
qlfarm is offline
post #4 of 15 Old 10-23-2012, 09:31 AM
zeus87gn
1987 YJ Wrangler
No adjustment on the YJ clutch - but you can bleed it for air
Most of my clutch problems on our two YJs are solved by a few minutes of bleeding
Your 90 should have the internal slave - they are prone to developing air by design, but fresh fluid keeps them going
Master cylinder for the clutch is on the firewall between the brake booster and the fender
Get yourself a 1/4 end wrench, a small crescent, DOT4 brake fluid (for the higher boiling point) and a helper to push the pedal
Check fluid level
Break loose bleeder screw with 1/4" wrench, hold larger fitting with crescent
Push pedal down
Close bleeder screw
Repeat as needed, but dont allow the master cylinder to go dry
After a few hundred miles, do it again and you will notice the difference of the DOT4
HTH
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #5 of 15 Old 10-23-2012, 12:49 PM
Opihi59
from here it gets rough
Opihi59's Avatar
You will likely find that your fluid is low in your clutch master cylinder reservoir. You could see fluid leaking INSIDE the firewall where the rod comes thru and connects to the clutch pedal up under your dash. Look thru this thread, it will help. http://www.jeepforum.com/forum/f12/c...cement-728960/ If your fluid is low but the firewall is dry, then you may be losing fluid from your internal clutch slave. That's a bigger problem though.
The issue you describe does sound like clutch hydraulics though, rather than a transmission problem per se.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #6 of 15 Old 10-24-2012, 07:20 AM Thread Starter
qlfarm
Thanks for the link. I will check my MC when I get out of work and see what the deal is. I have not seen any fluid inside of the firewall; but I haven't looked to be honest. I will check that also.
I saw some scary pictures of the bleeder valve and rust/scale/crap in the other thread. What happens if I break off the bleeder? Can I use a compression fitting to attach another bleeder fitting to the line? Is there another way to do this?
Worse case (which is always the case with my YJ) is the slave is bad. How hard is it to change this? I have never messed around down there and do not want to screw things up.
Thanks again for all fo the info!
Pat
qlfarm is offline
post #7 of 15 Old 10-24-2012, 11:04 AM
Opihi59
Opihi59's Avatar
Folks have used compression connectors etc to rig up a way to bleed their internal slaves. The job to replace it is onerous, you have to pull out the transmission so may as well replace the entire clutch at that point. Internal slaves are notorious for being bad right out of the box, so only go with OEM, even if you have to pay way more and get it from the dealership. It's better than replacing it 3 X in a row in very short order.
Let us know what you come up with.
Opihi59 is offline
post #8 of 15 Old 10-24-2012, 11:41 AM
StillYDGN
Exactly, I had mine go out three times in the matter of two months after paying a shop700 to replace it in my old 92. So frustrating. Never taking my new 88 to the shop. Ever.
On another note where is this bleeder u speak of? Id like to try it. My pedal usualy hits the floor when i have to shift. It has a b/a 10 with an interanel.
StillYDGN is offline
post #9 of 15 Old 10-24-2012, 12:04 PM
Opihi59
Opihi59's Avatar
This thread--http://www.jeepforum.com/forum/f19/yj-trans-swap-ba-10-5-ax-15-write-up-312203/
Look at picture #3 in post 2 of this, it shows the bleeder fixture on a BA 10/5, next to the disconnected hydraulic line that would be coming from the clutch master cyl.
If you need to disconnect the line, the fixture on the transmission side is the one that turns, the hex fixture on the end of the line from the master is "fixed" while the one on the tranny side of the connection is the one that turns. This is for the BA.
Opihi59 is offline
post #10 of 15 Old 10-24-2012, 01:10 PM
StillYDGN
Thanks man! Ive actually been reading through that swap thread for awhile. Starting to save to do the swap myself.
post #11 of 15 Old 10-25-2012, 08:51 AM Thread Starter
qlfarm
Looked last night; the MC is empty and I can't take the cap off to add fluid (why would you put a brace rod directly over a MC access lid). I looked for the bleeder but couldn't find it in the dark; looking at the pictures in the other thread I guess it is on the passenger side.
I am going to try adding fluid and see if I can bleed it; I really am not in the mood to pull a tranny this Fall.
Hopefully I will have some time this weekend to address the issue and see where we are.
qlfarm is offline
post #12 of 15 Old 10-25-2012, 01:56 PM
Old4X
1990 CJ7
A 9/16 wrench on the 2 front nuts and the rod swings out of the way. The bleeder is under your right foot area on the driver's side, get a flashlight and you will see it. The hyd line goes into a rubber stopper in the bell housing, and the bleeder comes out of the same stopper. Takes a 1/4 inch wrench.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #13 of 15 Old 03-22-2015, 12:14 PM
beinnvorlich
What's likely the problem when all the clutch engagement happens with very little movement of the pedal off the floor? My 94 yj goes into every gear no problem but the all the action happens in the first couple of inches of travel when releasing the pedal. Its an external slave with a bleed valve.
beinnvorlich is offline
post #14 of 15 Old 03-22-2015, 03:23 PM
nyyj1989
I have the same issue with mine using an external slave.
If you are using DOT 4 fluid you may actually have some moisture in the line.
If you can drain the old fluid and fill and bleed it, you should be ok.
I actually had this problem with the brake system on another vehicle.
nyyj1989 is offline
post #15 of 15 Old 03-22-2015, 05:42 PM
GreyBeard51
My 1992 acted similar
My '92 YJ 4 cylinder, acted the same way, plus I was loosing fluid around the clutch actuating cylinder.
I put in a new actuator (it was internal). and a new clutch while it was apart. Problem solved.
I think the previous post is correct, "there is no adjustment. I was also told that driving it that way would eventually wipe out the synchronizers in the transmission.
Good Luck!
GreyBeard51 is offline
