Yj clutch - JeepForum.com
post #1 of 5 Old 10-11-2013, 10:36 PM Thread Starter
Mattias25
Yj clutch
When my clutch petal is pressed in, it loses pressure and engages. Master cylinder is new, put on around Christmas
Mattias25 is offline
post #2 of 5 Old 10-11-2013, 10:38 PM
Fuzzy_Wuzzy
It sounds like your slave may be going out (often after the master goes out the slave will too) see if there is fluid coming out the bottom of the bellhousing. Mine took awhile for the fluid to show up there, but i would bet that is where your problem is.
You might try bleeding it again, but I doubt it is air if it slowly re-engages
Fuzzy_Wuzzy is offline
post #3 of 5 Old 10-12-2013, 06:38 AM
roadyrob
1987 YJ Wrangler
if you don't have a leak it sounds like a bad master, a lot of replacement parts don't last. I just changed my original master yesterday, pretty sure I won't see anywhere close to 26 years out of the replacement.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #4 of 5 Old 10-12-2013, 10:43 AM
Fuzzy_Wuzzy
Yeah this could be too. They are expensive, but I like the OEM master cylinder, it seems to be better than most of the aftermarket ones.
This is the hard thing about having an internal slave is that you do everything you can to make sure it is not the slave first.
post #5 of 5 Old 10-15-2013, 11:18 AM Thread Starter
Mattias25
Well! I replaced the slave, wasn't bad as all lol it was the master that was bad, but I got the excuse for gear oil for the trans so I'm happy
