YJ/CJ hardtop question? - Page 2 - JeepForum.com
post #16 of 19 Old 06-21-2010, 09:52 PM
pghohnst
Originally Posted by monkeyhouse View Post
I'll just say yes it should work. You will have to move the latches on your tub for the cj doors and you will probably have to un bolt the windshield to get the doors and top in correctly, but the dimensions are the same for a cj and yj. I have a hardtop from a 78 cj on my%2
I've got a CJ hardtop for my '95. I don't "move" the latches when I put it on - I just REmove them. The latch on the door connects with the tub well enough that it works. I've never had to unbolt my windshield either, but I'm guessing I could probably get a better fit if I did.
If you haven't already, you'll want to buy a good set of torx head sockets before you go switching the tops.
pghohnst is offline
post #17 of 19 Old 06-21-2010, 09:52 PM
dtn8tr
Not to Hijack but a quick question. My YJ has a soft top and I've been looking into getting a hard top...do I have to remove all the soft top belt rails to install the hard top and how does it attach to the windshield?
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #18 of 19 Old 06-21-2010, 09:59 PM
pghohnst
Yeah, you'll have to take that stuff off - the hardtop uses a few of the same bolt holes.
My hardtop (again, it's from a CJ) only has one bolt hole along the windshield that lines up, with the existing holes in my YJ, but that does well enough to hold it town at highway speeds. (I've actually driven 10 hours on the highway without bolting it to the windshield without problems, so long as it's bolted town well enough in the back).
pghohnst is offline
post #19 of 19 Old 06-21-2010, 10:00 PM
monkeyhouse
yes, you will have to pull the channels. Depends on what hardtop you get, but typically there will be holes that are for screws for the windshield.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
Hardtop Question jhaycock13 TJ Wrangler Technical Forum 6 09-26-2008 10:15 PM
Quick Hardtop Question - Will an 04 hardtop fit an 01? Sparty TJ Wrangler Technical Forum 5 07-18-2008 05:47 AM
hardtop question...will it fit? greta TJ Wrangler Technical Forum 2 06-03-2008 01:16 PM
Hardtop question shimmy TJ Wrangler Technical Forum 1 10-29-2007 03:28 PM
Hardtop Question UKTJ TJ Wrangler Technical Forum 4 09-11-2007 02:50 PM
