YJ to CJ dash swap write up with pictures
#46 | |
I bought a coolant temp switch for the cj is that the correct one or did I the remp sending unit ? they listed two different ones.
#47 |
That's the correct one!
#48 |
(I have an 87, I want to do this really bad now
looks awesome |
#49 |
Awesome, thanks I just wanted to make sure I had the right one before a retaped the head and messed it up, Do you happen to remember what size/thread tap you used to retap the hole ?
#50 |
Actually, No I dont' I just went through my kit sizing it up, it took all of about 5 minutes to do. You. should be ok.
If you don't have a kit take it down to the local HW store and size it ip there ![]() |
#51 |
ok, will do. I'm so close to getting this done i'm just out of parts so I'm waiting for some stuff from quadratec. I'll put up some pics when its finished. Your chrome dash looks mint how bad did they whack you for the plating? I woulda liked that too but I had a chrome overlay on my yj dash that was a gift my wife bought me and it looked good but the sun hit it and got me right in the eyes all the time so I decided to just paint my cj dash body color. I did two stage lacquer in rattle can I got factory color mtached from paintscratch.com I wet sanded it and buffed it out and It looks nice. I like how you did the accents in body color with the glovebox door and steering column trim too. I ended up using some hammered finish paint on mine that I used on my bumpers so it ties it in a bit. I decided to leave the center gauge overlay off too because it think it made it look overdone and I really wasnt happy with the fitment of it. Hopefully my parts get here tomarrow so I can finish it up, although im not really looking forward to dropping the tank to change that sender, maybe ill get that dropped tonight to get that out of the way.
#52 |
The plating shop bent me over for a cool $200.00... Ouch it was bad but, I couldnt complain on how it turned out.
If you look at one of the new ones with Diamond plate, etc. there in the same neighborhood so, I don't feel too bad! |
#53 |
yea true enough. Yours looks way nicer then those crappy diamond plate ones anyway, I would immagine none of the gauges of anthing that mount from the front of the dash would sit flush with out grinding the ridges in the diamond plate down.
#54 | |
maybe a question in the CJ forum. |
#55 |
Ha I spent 20 mins finding the right tap only to find out it was already the right size which was awesome because that was not looking like a fun spot to be tapping out a hole. My cj temp gauge works now which is good but I had bought a new set of replacement gauges to go in the cj speedo cluster from quadratec, I wonder if it will be the same thing when I get the fuel sender. I guess it would be nice not to have to take the speedo cluster back out now that its all wired up and all the lights are in it but they whacked me almost 70 bucks for those two gauges, I wonder if I can send em back or maybe I should hang onto em for spares.
#56 |
strange that it fit, but cool~
#57 |
I do have a much newer motor from a 2005 tj but still it was the yj sending unit for sure. kinda wierd the tj didnt use that sensor at all so there was just a boss cast into the head for it but we had to drill a hole in it and tap it ourself to be able to use the yj sender. Definatly glad I didnt have to tap it out though there wasnt much room there with the fuel rail and the fire wall was real close. My luck I woulda snapped the tap of in the head or something too so it made my night when the thing just screwed right in. Alittle teflon tape for good measure screwed it in crimped on my new terminal and I was good to go. Guess i'll start dropping the tank now.. what fun, maybe all fix the rot hole in my frame while I have the tank out of there so I wont have to worry about blowing the thing up when I weld in the patch.
#58 |
Location: Stuart, 30 miles north of West Palm Beach, Florida
I've got a dumb question, how does the speedo cluster attach to the dash? Here's the back of mine:
![]() The voltmeter and oil pressure gauge both have tabs that clamp to the back side of the dash, but, the main speedo cluster doesn't, or, at least this '76 model doesn't. Now, I see the tabs on the outside of it that look like screws go through there, but, how does it attach to the dash, are there captive nuts on the back side of the CJ dash? One other question, where can you get the bulb sockets for these gauges? Thanks!! Jerry ![]()
1992 Jeep "CJ9" (YJ with '78 CJ front clip, '80 CJ Tailgate, Custom CJ Dash with '76 CJ Gauges) AX-15 from a '93 YJ, 2.5" Rancho SL, 5/8" MORE booms, 1" BL, and 33"x10.50" SS TSL's |
#59 | |
#60 |
I bought the bulb sockets at parts stores, they only have one wire on them and they ground through the gauge cluster. The 4wd light and brake warning light use 2 wire buld holders but you should be able to reuse some stock yj ones for those.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
