YJ Chat and non tech - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ Chat and non tech
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 07-20-2012, 01:18 PM   #91
jeepster93
jeepster93's Avatar
Was towing my Jeep the other day from the bank-home. Have sense fixed the issue, a wire to the fuel pump. A bear to diagnose.
But anyhow...
I broke my tow strap. It was old(ish) and most likely cheap. Lucky me, it broke turning the corner to my street.
I got a new one and it has stretch to it. 20% on a 30 foot rope.
I can not tow with this...Right?
Or can I?
I also got a higher rated strap than I just broke. Got one rated 17,500 pounds. This higher rating caused it to be thicker. From 2 to 3 inches.
Last year i lost my tree strap(well, forgot it and left it on a tree) and did same, got one longer and thicker.
Now all these straps will not fit in my recovery bag.
Went to the 4x4 store and saw one but it was $60. For a carry bag.
Went to Big Lots and got an athletic gear bag for cheap($12).
Sweet:
jeepster93 is offline   Reply With Quote
Unread 07-20-2012, 03:32 PM   #92
Anticanman
Anticanman's Avatar
Originally Posted by jeepster93 View Post
So...
Non tech talk....
My oba.
A belt driven Saneen custom modded for oba. An Extreme air.
Besides the point.
It leaks. A 2 1/2 gallon tank, 2 locker connects, a tire fillup connect and a gauge with the connecting parts all soft copper 3/8 inch tubing.
I will fill it up to 105 psi and it looses about 15 psi in 1/2 hour and will recycle the compressor without me using any air.
Can/t find the leak. I sprayed the connectors with soapy water and got no bubbles.
My thinking- the check valve is leaking. it is mounted close to the compressor and gets real hot. The check valve HAS to be as close to the compressor as it can...Right?
Do I go spending time and money on a 15psi leak in 1/2 hour?
I've found that I have the same problem. Did you get yours fixed?
Luck favors the prepared
Originally Posted by squarelight94 View Post
You're the Oprah of jeeps, slap your name on it and it sells like hot cakes!
Originally Posted by jbolty View Post
I would like to thank everyone who thanked Anticanman.
Originally Posted by egodfrey
Well canada is a different story this is american talk here silly :rofl:
Anticanman is offline   Reply With Quote
Unread 07-20-2012, 09:05 PM   #93
jeepster93
jeepster93's Avatar
No...
I think it is leaking back into the compressor. The check valve is not sealing. It is real close to the compressor and got fried, they can get hot.
Not sure what I'm going to do about it. I think it needs a new check valve.
Unread 07-20-2012, 09:18 PM   #94
moonpie312
No...
I bet your right, and to answer your previous question, no, it doesn't necessarily have to be as close as possible to it. You do want it in the line before anything else T's off the line, but I would move it a little away from it to help with the heat.
moonpie312 is offline   Reply With Quote
Unread 07-20-2012, 09:25 PM   #95
Anticanman
Anticanman's Avatar
I've got my check valve 12 feet away from the compressor and I'm still having leaking problems. I just can't pinpoint where though. Perhaps a little soapy water will tell.
I know I have a leak before the check valve but it shouldn't matter because my pressure valve is connected to the tank at the inlet hose. Jeepster: which check valve did you go with? Perhaps it's faulty like mine
Unread 07-21-2012, 07:04 AM   #96
mark0530
brittney spears song going thru my head!
OOPS I DID IT AGAIN! Proud owner of 1990 hardtop full door jeep wrangler. Last yj I had took a year (2010-2011) to put back on the road. Lot of first time experiences doing it. Learned to weld on it. Learned to paint on it. Etc... in the end bought for 1800 and sold for 3000. Still occasionally see the jeep on the road, so I guess repairs worked. It was for my kid to try. Turns out she liked the jeep just not the stick so i sold it and found an 02 auto tj. Now I get to start on this one. Driver floor board is gone, fenders need replaced, all 4 corners of frame will need some attention, couple holes in the body and the windshield frame need repair or replaced. This time only out 1600!
Signed....hooked on jeeps! Well actually hooked on repairing jeeps.
mark0530 is offline   Reply With Quote
Unread 07-21-2012, 03:21 PM   #97
Louie4
Injanir
Louie4's Avatar
Sweet. It's sad because when I first read your post it reminded me of the Brittany Spears song.
You going to start a thread for this one?
Lou
Poison Spyder Fender Install
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is online now   Reply With Quote
Unread 07-24-2012, 11:05 AM   #98
jeepster93
jeepster93's Avatar
What do you think?
I just bought a set of 4 33x12.50x15 Goodyear MTR's with 200 miles on them for 6 1/2 bills.
Discount sells them for 232 each plus taxes. (new of coarse)
Unread 07-24-2012, 11:08 AM   #99
ohio79
Delete
ohio79 is offline   Reply With Quote
Unread 07-24-2012, 11:53 AM   #100
ohio79
See ya folks around!
Well ive done it. Sold my last YJ. I am still with the jeep community as I bought a TJ. Just wanted to say thanx for everyones help. Good luck and safe journies.
Unread 07-24-2012, 12:48 PM   #101
jbolty
ISO 9001 Compliant
jbolty's Avatar
Good luck in whatever you do.
Not tech.
I'm moving it again.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 07-24-2012, 03:39 PM   #102
BIGHEEP
Nevermind.
1988 Wrangler YJ Laredo, 4.0L H.O., AX-15,
NP231 w/HD SYE,D44 locked/D44 w/LSD,4.09 gears
Build thread http://www.jeepforum.com/forum/f12/m...igheep-534340/
1990 YJ, 4.0L HO, AW4 and NP231 (out of a 97 XJ)
North East Willy Jeep Organization
www.NEWJO.ORG
BIGHEEP is offline   Reply With Quote
Unread 07-25-2012, 12:09 PM   #103
iced98lx
A couple Vanity shots of my 95 YJ
Included it in a few shots for our engagement photos, thought you guys might enjoy these. I have a ton more with the heep but these stood out the most to me.
iced98lx is offline   Reply With Quote
Unread 07-25-2012, 12:14 PM   #104
djwrangler
Nice pics! Yeah, I pretty much married my Jeep too lol.
djwrangler is offline   Reply With Quote
Unread 07-25-2012, 12:35 PM   #105
bill8bud
bill8bud's Avatar
She (YJ) will take half now instead of waiting.
Nice looking rig
bill8bud is offline   Reply With Quote
