YJ Chat and non tech - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ Chat and non tech
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineHMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IDISCOUNT LOCKER and AXLE SHAFT Days Sales at Baseline 4x4
Unread 07-15-2012, 07:39 PM   #76
USMCBuckWild
Originally Posted by tdewit View Post
USMCBuckWild, I couldn't agree with you more.
Regarding
True. My words may have been a little too strong in the context. A little common sense goes a long way.
Its all good man, I know what you were trying to say, just took an opportunity to poke a little fun.
We have all been in a situation where we had to do something goofy or insane to get by. Not doing that when we have the proper tools at hand is the key. We al need to pass on the knowledge we have acquired over the years to the younger generations. I can honestly tell you I am a student at the "School of Hard Knocks" and have yet to graduate. I have the scars and stories to prove it.
It sometimes takes a strong man to admit his mistakes. I preach to my Marines every day; "A smart man learns from his mistakes, a Wise man learns from the mistakes of others" i have no problem explaining the dumb things I have done in an effort to keep someone else from making the same mistakes I did.
Safety is paramount, so lets keep it safe!
USMCBuckWild is offline   Reply With Quote
Unread 07-15-2012, 07:44 PM   #77
UltimatE
Resident Audio Guru
UltimatE's Avatar
Originally Posted by moonpie312 View Post
Granted, I'm sure we have all done some crazy things.
But hey, at least I put a chain around it so there was no way it could slide off the air jack. I was doing my exhaust all from scratch.
One other thing I always do is shake the crap out of it before I get under it, I would rather my Jeep get hurt than me get hurt.
http://i873.photobucket.com/albums/a...0303121828.jpg
What the s*** is that? What a terrible way to lift a vehicle.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Unread 07-15-2012, 08:23 PM   #78
G30SFF250
Originally Posted by Louie4 View Post
Pete you know the old saying, whatever doesn't kill you makes you stronger. So you must be plenty strong!
Glad you got everything taken care of!
Speaking of things to get done, I need to put a trailer harness on my jeep. I'm going to pull a trailer up to TN.
Sounds like you are leaving GA for TN.
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline   Reply With Quote
Unread 07-15-2012, 08:57 PM   #79
moonpie312
It's better than I've seen other people do. And what exactly is wrong with it? jack stands in the back and the air jack in the front? The air jack is often more stable than jack stands. Yes I know the pads are a little unnerving to look at but I preloaded the chain around the whole setup so as it went up it tightened. It is completely impossible for it to slide off in any way.
And like I said, I always shake the vehicle very hard before I even think about getting underneath it to prove its safe. So maybe lighten up a little bit eh? Its not like I just jacked it up and slid under and trusted it to my life? I have lifted many vehicles this way and never had a problem. If I had a better spot to lift than the springs I would have. Besides it is higher in the air than it looks, there was no other way to get it that high, I had to lift the back with the air jack, put the stands under and then move it to the front. You don't have to be an *******.
moonpie312 is offline   Reply With Quote
Unread 07-15-2012, 10:30 PM   #80
imstillatwork
It goes with the shackles, though.. no?
HELP! Someone in Oregon... I NEED AN AX-15!!
imstillatwork is offline   Reply With Quote
Unread 07-16-2012, 04:42 AM   #81
Louie4
Injanir
Louie4's Avatar
Yep. There will be too much orange for me especially since I'll be starting my masters at UT.
Lou
Poison Spyder Fender Install
My Dumb Ole' Build Thread
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote
Unread 07-16-2012, 05:47 AM   #82
USMCBuckWild
Those shackles are pretty scary. If this was a who has the biggest shackle contest, he would definately be the winner!
Unread 07-16-2012, 07:32 AM   #83
jeepster93
Were wires crossing and/or grounding out?
It would work then not work. Only failing on starting, if the heap would start I was golden, starting was the issue. Would disconnect it and do a continuity check and good. Would reconnect it and nada. Like there was rust inside the connector.
Took me months to find that little POS!
jeepster93 is offline   Reply With Quote
Unread 07-16-2012, 09:42 AM   #84
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
As nobody has added anything helpful to this thread I will. It's not YJ tech and does not belong.
WRONG
RIGHT
Poke is online now   Reply With Quote
Unread 07-16-2012, 10:28 AM   #85
tdewit
Yep to ^^
tdewit is offline   Reply With Quote
Unread 07-16-2012, 11:15 AM   #86
USMCBuckWild
[quote=Poke;13874588]As nobody has added anything helpful to this thread I will. It's not YJ tech and does not belong.
Good pics!
I think a few people have added some helpfull things but maybe not with pics.
Unread 07-16-2012, 12:59 PM   #87
Anticanman
Anticanman's Avatar
Nice move to non tech!!
Luck favors the prepared
Originally Posted by squarelight94 View Post
You're the Oprah of jeeps, slap your name on it and it sells like hot cakes!
Originally Posted by jbolty View Post
I would like to thank everyone who thanked Anticanman.
Originally Posted by egodfrey
Well canada is a different story this is american talk here silly :rofl:
Anticanman is offline   Reply With Quote
Unread 07-16-2012, 08:29 PM   #88
moonpie312
You know not everybody can afford those fancy shackles, these came from O'reilly's for 10 bucks and in the first hole where they currently are, it only gave a 1 inch lift. I haven't had the time to take them back off and cut off the excess and weld a brace in the middle. Biggest shackle contest winner I would take the award if it was in the bottom hole. People like you and the others make a person not want to own a Jeep.
Unread 07-18-2012, 04:46 AM   #89
tonymartin
Lighten up a bit mate, it's only fun!
As for the stupid stuff being done with jacks. I once had a guy try to lift my ZJ with a Hi-Lift by the rear fender in the desert on a slight incline with the side he was trying to lift facing down hill. Needless to say that guy never came near me with his stupid suggestions any more!
I like the beaver shackles idea if you're on a tight budget. Just the same (in theory) as a ZJ budget boost, only goofier looking!
93 YJ 4.0. aka the red renegade. 2" shackle lift with Rancho adjustable shocks. 31x15 BFG AT's. 15" GT alloys. Five spot lights. Custom headers.
Three peice Bikini top with back seat delete. Some crap in the back and a tool box that'd put most mechanics to shame!
tonymartin is offline   Reply With Quote
Unread 07-18-2012, 08:56 PM   #90
moonpie312
Originally Posted by tonymartin View Post
lighten up a bit mate, it's only fun!
As for the stupid stuff being done with jacks. I once had a guy try to lift my zj with a hi-lift by the rear fender in the desert on a slight incline with the side he was trying to lift facing down hill. Needless to say that guy never came near me with his stupid suggestions any more!
I like the beaver shackles idea if you're on a tight budget. Just the same (in theory) as a zj budget boost, only goofier looking! :d
Hahaha! Oh man you just made my day. Beaver Shackles.. I can't stop laughing now
