YJ Chat and non tech - Page 470 - JeepForum.com
 1880Likes
post #7036 of 21766 Old 12-12-2013, 03:12 PM
skyj
I've been having the same problem with my wife's dd '03 trailblazer cant complain though since its never given us troubles until now 187, 000 I have an engine miss but can't pinpoint which cylinder no service engine soon light and no code it's driving me crazy we plan to sell it soon for a newer vehicle so I don't want to dump a ton of money into new coils on it.
build thread:
skyj is offline
post #7037 of 21766 Old 12-12-2013, 03:20 PM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Mine threw a code. And I swapped the coils to make sure the miss followed the bad coil. Maybe unplug one at a time till you find the one that doesn't cause a change? Are you sure it's a miss? On mine the engine shook pretty bad and I couldn't get it to rev over 3k in park.
Randonexplosion is offline
post #7038 of 21766 Old 12-12-2013, 03:25 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Had the same problems and more with my 03. There is no recall for all the serious problems with it. Cut your losses and sell it. I did.
Luck Favours The Prepared
Anticanman is offline
post #7039 of 21766 Old 12-12-2013, 03:41 PM
skyj
I tried unplugging them and no change at all, only does it under load like with the heat/ac on. Its gets really bad when cruising at around 55mph. Cleaned throttle body and replaced plugs and o2 sensor im tired of throwing parts at it.
build thread:
skyj is offline
post #7040 of 21766 Old 12-12-2013, 03:54 PM
Randonexplosion
Deplorable
Thats wierd man. So with heat or AC off it is fine? Mine runs like a top now with 184k. I like these engines and they have a 4l60e behind them. I cruised 90-95mph back from Phoenix and still got over 20 mpg.
post #7041 of 21766 Old 12-12-2013, 03:57 PM
AmmitOsiris
AmmitOsiris's Avatar
So what would a YJ with a 5.3 and a 5 speed get??
Because I Saved 15% On My Car Insurance
AmmitOsiris is offline
post #7042 of 21766 Old 12-12-2013, 04:11 PM
Randonexplosion
Deplorable
Doing 90-95? probably about 8mpg.
With correct gears it will do well. Mine does low 20s with 33s/4.10s and the 4 speed auto. 1950rpm @ 65... poifect
post #7043 of 21766 Old 12-12-2013, 04:27 PM
skyj
Not always if im sitting there letting it idle its fine but as soon as I raise the rpms it starts to miss, and wont go above 3k like yours, but I was under the impression that was a safety feature. Its been like that as long as I can remember, but the miss has been going on for over a month and not getting any worse. I've tried almost everything except replace coils.
build thread:
skyj is offline
post #7044 of 21766 Old 12-12-2013, 04:34 PM
Randonexplosion
Deplorable
I agree, you'd think the rev limiting would be caused by a limp mode from a code being thrown. Are you sure there is no code or there is just no "service engine soon" light? You definitely want to know a coil is bad before you replace it. $80 a piece at Napa/Carquest. The dealership wanted $218
post #7045 of 21766 Old 12-12-2013, 04:43 PM
skyj
Yea no code I have one of those obdII code readers with an app on my phone and I monitor it frequently no thrown codes just a drop in rpm while driving I just need to do dome more research on what everything else means on the diag on the reader. I even started a thread on trailvoy.com and no one seems to know what to fix either. Everyone just tells me to clean the tb and change plugs.
build thread:
skyj is offline
post #7046 of 21766 Old 12-12-2013, 04:44 PM
calvynandhobbs
calvynandhobbs's Avatar
I don't have a GM, but my F250 started missing sporadically in the cold weather. It threw no idiot lights at me, but I scanned it anyway and there was a code that gave me cyl 2. i swapped the coils around to see if I could get the miss to change and it did about a month later. There was a hairline crack in the coilpack and it only caused a miss in cold temps. No idiot light does not mean its not throwing a code.
94 YJ - work in progress
calvynandhobbs is offline
post #7047 of 21766 Old 12-12-2013, 04:44 PM
RikRotorhead
I sure hope they didn't Hollywood the crap out of episode 2. It looks like they may have.....
https://www.youtube.com/watch?v=jGEERBDelH8#t=36
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #7048 of 21766 Old 12-12-2013, 04:45 PM
calvynandhobbs
You posted while i was typing.
post #7049 of 21766 Old 12-12-2013, 07:14 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
x2!
Jeeze. It's been into the negatives at night here. Today's the warmest day in over a week at 18* for the high.
Freaking 'tards.
Cheers
Same here, I find it that the Media had to inform people how to live. However it is just common sense ! Oh wait common sense is not very common anymore ! Thus another reason I belive we should have to take IQ, and put people in certain scenarios to test their ability to survive and think on multiple levels before they are allowed to vote or breed .
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #7050 of 21766 Old 12-12-2013, 08:31 PM
AmmitOsiris
Doing 90-95? probably about 8mpg. With correct gears it will do well. Mine does low 20s with 33s/4.10s and the 4 speed auto. 1950rpm @ 65... poifect
What if someone had an ax15 behind one..
This is not exactly tech gt4660 JK Wrangler Technical Forum 5 12-24-2007 05:56 AM
Water-proofing the Jeep...console, upholstery, etc. Let's chat. bman9089 TJ Wrangler Technical Forum 16 05-15-2007 06:38 AM
Need a little tech help. tautog27 TJ Wrangler Technical Forum 8 04-21-2006 12:35 PM
8.8 tech Greencar YJ Wrangler Technical Forum 4 09-20-2005 05:13 PM
