YJ Chat and non tech - Page 273 - JeepForum.com
 2064Likes
post #4081 of 22203 Old 09-11-2013, 11:14 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
there aren't enough black pixels on the average smart phone or computer screen for me to play...
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #4082 of 22203 Old 09-11-2013, 11:17 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Don't give yourself a hard time, Tim. You look good in shorts.
Anticanman is offline
post #4083 of 22203 Old 09-12-2013, 07:48 AM
Gage56
Love this guy LOL
1992 YJ
Gage56 is offline
post #4084 of 22203 Old 09-12-2013, 09:14 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
A bit of a toolbag
Randonexplosion is offline
post #4085 of 22203 Old 09-12-2013, 01:31 PM
scraper
Convince me to spend the money. Someone listed this locally on Craig's list for $300obo. Keep in mind I have a dana 35 rear currently:
Im Selling A Ford 8.8 Out A V8 Explorer Disc Brakes. Had It Under My Wrangler For 3 Years And Only Ever Had To Put Brakes On It. I Completely Rebuilt It Before I Swapped It in. Installed Yukon 4.10 Gear Ratio And New Limited Slip Clutches And Always Ran The Trak Lok Oil. Along With New Bearings And Seals. It Does Need A Few Wheel Studs And The Carrier Has Been Light Damaged Before I Got It. But Is Painted And Good Shape. Also Incudes Bullet Proof Diff Cover
I text the guy and he still has it. I ask him why he's getting rid of it, he says he wants a 14 bolt one. Am I nuts for passing on this? As near as I can tell that set up would cost me at least $600 if I found one in a junk yard.
scraper is offline
post #4086 of 22203 Old 09-12-2013, 01:38 PM
squishy
Get it! I paid $600 for mine w/ new gears and locker. Came with perches shock tabs and ubolts though. Make sure you get the flange bolts with it. They're semi hard to find.
squishy is offline
post #4087 of 22203 Old 09-12-2013, 02:20 PM
Randonexplosion
Deplorable
Is it setup for a YJ? Spring under? If so I'd be all over it. I spent $5-600 on mine with free welding from a buddy.
post #4088 of 22203 Old 09-12-2013, 02:27 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pass.
post #4089 of 22203 Old 09-12-2013, 02:37 PM
scraper
Why do you say pass? Also I think it is spring under and he had it on a yj.
scraper is offline
post #4090 of 22203 Old 09-12-2013, 05:16 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You'll have to adapt it to fit your pinion angle. Its more expensive than what you can find in the junkyard already.
post #4091 of 22203 Old 09-12-2013, 06:06 PM
scraper
Wouldn't I have to adapt the pinion angle of any 8.8 I would find in the Junkyard too?
scraper is offline
post #4092 of 22203 Old 09-12-2013, 06:14 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's my point. What makes this worth so much more than a junkyard axle? I mean, if you want it then get it. Personally I would trust the backlash on a junkyard explorer with low miles than any rebuilt on Craigslist. Besides, why is the carrier damaged? Why not just throw in a new one if you're going to not only rebuild the clutch packs but also do seals and bearings? It just smells fishy and I'm just trying to look out for you.
post #4093 of 22203 Old 09-12-2013, 06:33 PM
scraper
That's a good point about the carrier. I may go look at it and see exactly how damaged the carrier is. Maybe he's being overly honest and there is slight damage not worth worrying about or MAYBE he blew some gears up in it and it's not worth a darn. I'm hoping for the first guess.
scraper is offline
post #4094 of 22203 Old 09-12-2013, 06:47 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
What does an axle cost you at a junkyard? Do you have half off days?
post #4095 of 22203 Old 09-12-2013, 08:34 PM
ashland82391
Hey, i know this is non technical but I like it over here more than anyof the other threads.
Question:
Transfer case is whining/humming while under power. fluid is full and clean. Is this because of bad bearings or chain?
ashland82391 is offline
This is not exactly tech gt4660 JK Wrangler Technical Forum 5 12-24-2007 05:56 AM
Water-proofing the Jeep...console, upholstery, etc. Let's chat. bman9089 TJ Wrangler Technical Forum 16 05-15-2007 06:38 AM
Need a little tech help. tautog27 TJ Wrangler Technical Forum 8 04-21-2006 12:35 PM
8.8 tech Greencar YJ Wrangler Technical Forum 4 09-20-2005 05:13 PM
