YJ Chat and non tech - Page 142 - JeepForum.com
 2949Likes
post #2116 of 23763 Old 06-04-2013, 10:57 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
Originally Posted by rawlston
Haha I hate when that happens. My gf got mad at me once because I was paying more attention to the front suspension of an xj sitting outside than I was to her.
I think we've all been in that spot.
Michaelgoesrawr is offline
post #2117 of 23763 Old 06-04-2013, 11:47 PM
Xpress
Thinking about ditching my NP231 for an NP242 t-case to go behind the V8.
Ideas???
All about that unibody life.
Xpress is offline
post #2118 of 23763 Old 06-04-2013, 11:58 PM
zte87
GIVE IT THE ONION
zte87's Avatar
Ideas???
You wanting then awd option?
zte87 is offline
post #2119 of 23763 Old 06-05-2013, 09:13 AM
navinke
Still trying to decide
navinke is offline
post #2120 of 23763 Old 06-05-2013, 10:18 AM
Xpress
Could have sworn the 242 is part time 4x4 whereas the 249 is the AWD option.
Xpress is offline
post #2121 of 23763 Old 06-05-2013, 11:36 AM
zte87
GIVE IT THE ONION
zte87's Avatar
It's is but I always thought part time and awd where the same thing??
zte87 is offline
post #2122 of 23763 Old 06-05-2013, 12:14 PM
skyj
I saw a YJ at Walmart today that had a sticker on it that read " its a TJ thing you wouldn't understand". The owner was getting out of it at the time so I walked by and said "nice TJ" he said "Thanks Dude!! I put a lot of time into her to make her nice".
I wished I would of got a pic it was a driving hardware store with towel racks for a push bar and home heating louvers cut out in the hood. Chicken wire for light guards and chrome stickers all over everything.
I chuckled and got in my truck, he didn't catch my sarcasm.
build thread:
skyj is offline
post #2123 of 23763 Old 06-05-2013, 02:18 PM
dillonjm
2013 WK
Full time and awd are the same. Part time is the new lingo for 4 high.
The 242 has 2wd, 4 full time, 4 part time, and 4 low.
It essentially just adds an AWD option in addition to the standard ranges the 231 has.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #2124 of 23763 Old 06-05-2013, 02:43 PM
remmons
I can confirm that the 242 is the part time and full time 4WD with a part-time 4LO. This is what I had yanked out of an '88 XJ for use in my YJ. I love this option for two reasons; 1, in the winter I can shift to full time 4WD for when I have patches of ice and snow on the roads, and 2, to use when I am climbing or driving on a sandstone shelf to prevent driveline binding.
If I remember correctly, the 249 is only a full-time and does not have a 4LO option, but I will let the experts chime in on this.
Edit: This is what I had pulled up on the 'net, and I was correct;
"The NP-249 which is a full-time transfer-case that utilizes a viscous coupling to act as a limited-slip betweed the front and rear driveshaft. One of the main drawbacks of the '93-95 ZJ version of this case is the lack of a low-range lock. In other words, if you get into a sticky situation and need both driveshafts turning to get you through, this transfer-case will only act as a limited-slip and not mechanically lock the two driveshaft to turn in unison."
Robert.
remmons is offline
post #2125 of 23763 Old 06-05-2013, 05:19 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The VC goes out a lot on the awd Transfer cases. Stick to the 231j with bits of the 231c to beef it up.
Luck Favours The Prepared
Anticanman is offline
post #2126 of 23763 Old 06-05-2013, 05:56 PM
Xpress
It has low gear, I have one in my 96 ZJ.
I get mixed reviews saying that the NP231 is a weak transfercase and the moment I get a little giddy with the skinny pedal behind a v8 is when it will blend the internals, yet others have told me it's perfectly fine to use behind the V8.
Xpress is offline
post #2127 of 23763 Old 06-05-2013, 07:26 PM
Randonexplosion
Randonexplosion's Avatar
Mine has held up so far, and I have been taking advantage of the power I wish I would have listened to Anti and done the wide chain/planetary from a 231c while I had it apart, and I still plan to, but I think it will be fine. I think worst case ill stretch the chain first. I dont think my rear tires like me right now. Youll be fine
Randonexplosion is offline
post #2128 of 23763 Old 06-05-2013, 07:35 PM
Xpress
So perhaps I should just do the wide chain upgrade while I am at it since it's all out of the Jeep, and will be awhile before things start going back together.
Actually looking forward to putting a spotlessly clean and freshly Monstalined Jeep back together
Xpress is offline
post #2129 of 23763 Old 06-05-2013, 07:57 PM
Randonexplosion
Dont forget the 6 pinion planetary.
Speaking of, my buddy has a wrecked 94 blazer with an np233. Is it useless to me? I hoped it would have the 231c.
post #2130 of 23763 Old 06-05-2013, 08:34 PM
Steve707
What happened to the chicks?
Steve707 is offline
This is not exactly tech gt4660 JK Wrangler Technical Forum 5 12-24-2007 06:56 AM
Water-proofing the Jeep...console, upholstery, etc. Let's chat. bman9089 TJ Wrangler Technical Forum 16 05-15-2007 07:38 AM
Need a little tech help. tautog27 TJ Wrangler Technical Forum 8 04-21-2006 01:35 PM
8.8 tech Greencar YJ Wrangler Technical Forum 4 09-20-2005 06:13 PM
