#1 | |
YJ Cage, Bolt in?
I’m looking for feedback on bolt in sport cages for my YJ. Does anyone have any experience with one particular manufacturer over another? I’d like to add to the existing roll bar and replace the horizontals that mount to the window frame as well as add a dash bar and one across the upper window also. I also want to be able to tie it into the frame, though if possible I may do that later.
http://edjeep.blogspot.comMy Ride: '95 YJ ----- 2.5l 180,000 miles 2" BDS ----- 1" Daystar ----- 1" Shackle 33"x12.50" BFG MT Olympic Rocck Bumpers and Tire Swing ARB in D35 Rear ----- Warn 9.5ti to get me out Warrior / Warn / SkidRow / Currie / Shrockworks to keep from from beating it up too hard empty wallet |
#2 |
do it right the first time and pay the extra bucks to get a custom one welded on.
im not sure if they make a Tie in for the frame that is bolt on. but im not sure |
#3 |
there are plenty of bolt on kits now that are just as strong as your general moderately built welded cages. contrary to popular belief the bars wont slide or come apart. it is a good option for those without the tools and a bunch of tubing.
there are two basic types of cages. the first is designed to protect the driver, the second is designed to protect driver and itself. that is, it is designed to withstand a roll without deformation. a bolt in cage will live up to cage type ones parameters just fine. the majority of cages built are of this first type. the factory configuration will protect occupants fine in a mild roll-over. seen it and seen the effects. niether factory bars, weld-in "kits," or bolt-on cages will meet type twos parameters. these are built primarly where the vehicle needs to be able to continue without problems after a flop or roll. usually built for competitions etc. pioson spyder makes one for the tj. and rock hard 4x4 make components. |
#4 |
i have one for my 89 yj from this company, was a easy install and a well built cage
http://www.orfab.com/ |
#5 |
yeah it looks good but you cant tie it in the frame.
#6 |
I have the rock hard 4x4 bolt in cage, you can tie it to the floor and the frame. I trust the cage for crawl speed on what and where I wheel. It will take one hell of a cage to protect you from a highway roll so don't expect that in a bolt on kit.
#7 |
http://jeepsunlimited.com/forums/showthread.php?t=731886
atoz... it has floor plates to mount to the body or you can get rockers from them too and mount them to that with the bolts provided.. I'm happy with the cage.. |
#8 | |
that is hell of a cage looks sick! |
#9 |
*** While I do not know if this cage can be tied in w/ the frame- my friend has a Tennessee Offroad cage in his YJ. His is welded in ( again, don't know if that cage is weld in, or bolt in but can be welded in.)
Anyways, it looks very stout, but I remember my feet getting tangled up with the bars while entering or exiting the jeep. Other than that- seemed very durable! I figured I'd share seeing how I actuall had experienced a YJ with a cage in it.. ![]() |
#10 | |
Join a 4x4 Club
As it is now, it at least allows me to put the windshield down in the woods and minimize tree branch issues.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct. Member and Web guy: New Mexico 4 Wheelers |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
