YJ A/C and vent question - JeepForum.com
post #1 of 5 Old 09-07-2011, 01:29 PM Thread Starter
Jeepfan1
Did only the hard top YJs get the 3 air vents that protrude under the radio and A/C controls and the 1 under the glove box? Were the vents like that part of a package? Sorry for the silly question but I havent seen any soft top YJs with them yet.
/l , [____],
|---L--OlllllllO-
()_) ()_)==O=)_)
Jeepfan1 is offline
post #2 of 5 Old 09-07-2011, 02:06 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
The AC is a bolt on option. More common with hard tops from the dealer, but available with soft tops also.
- Ernie
Richmond88yj is offline
post #3 of 5 Old 09-07-2011, 02:46 PM
Bad_Dog
Yep. I got the Renegade package in my '91, and it came with a hard top. The AC blower unit was an add-on option.
OlllllO 2013 Wrangler Sahara Unlimited
[]lllll[] 1991 Wrangler Renegade, 4.0L Auto (Retired 2013)
Bad_Dog is offline
post #4 of 5 Old 09-07-2011, 03:22 PM Thread Starter
Jeepfan1
I see it now. Its like a whole unit as sold from jeepair.com that fits under the dash and it appears self contained. I have looked at some Jeeps that had that unit under the dash yet they also had the slide type temp select levers and blower motor speed select to the left of the radio as well as what appeared to be controls on the A/C unit under the dash. Whats up with that?
Did Jeeps come with A/C controls even if they didnt leave the factory with it and when its added later you just use the controls on the add on unit?
/l , [____],
|---L--OlllllllO-
()_) ()_)==O=)_)
Jeepfan1 is offline
post #5 of 5 Old 09-07-2011, 03:42 PM
Budke
The slider is to choose if you want hot air blowing for the defrost/heat or if you want outside temp air blowing. Those come in all YJs
The knobs on the a/c unit choose the power it blows out and how cold you want it.
I have a/c and it came like that. A lot of the saharas came from the factory with a/c.
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
TJ hardtop vent question zmiller TJ Wrangler Technical Forum 8 07-11-2012 12:38 PM
Vent switch pod question TheGuyFromNJ TJ Wrangler Technical Forum 2 05-01-2011 05:53 AM
Heating/AC vent question EJames1226 TJ Wrangler Technical Forum 6 08-24-2010 08:52 PM
ax-5 vent question nj95yj YJ Wrangler Technical Forum 5 06-12-2009 09:05 PM
A/C Vent Question Roothog TJ Wrangler Technical Forum 1 03-24-2006 06:07 AM
