YJ A/C Clutch Not engaging - JeepForum.com
post #1 of 13 Old 04-15-2011, 01:20 PM Thread Starter
thebeast64
OK guys, I posted about this on the OC roll call thread, but it doesnt see as much traffic as this so I figured that I would put it out there again. I have a factory A/C system that isnt functioning. The blower motor works, and the system blows out sorta cool air, but that is about it. Im not sure if the compressor clutch is getting power, so Im just curious as to how to check the Clutch relay and where it is. This is the wiring diagram that I have as or right now and its great, but it doesnt show exactly where the things are located. And its starting to get hot here in Socal, so my A/C is going to be needed soon!
thebeast64 is offline
post #2 of 13 Old 04-15-2011, 01:48 PM
lespaul_custom
when you turn the fan on, are you turning the knob to the right of it also? you could pull the plug on the compresser and test it with a voltmeter for power. if the system is low the hi/low switch wont allow the compresser to cycle at all. and the relay is in the power dist. box under the hood by the battery.
originally posted by urb4ntroll
The weird thing is that I thought I hear a minor bang, almost like a fart sound coming out of my Jeep, but I'm not sure what it was. It has never happened before the glue incident.
white jeep club #1993 looking to buy complete rear seat belts
lespaul_custom is offline
post #3 of 13 Old 04-15-2011, 01:52 PM
AZ94YJ
With the ac on run a jumper from the positive side of the battery to the clutch, and see if it engages... Then check your pressures, your pressure may be too low...
AZ94YJ is offline
post #4 of 13 Old 04-15-2011, 01:56 PM Thread Starter
thebeast64
Ok, So im going to go to orvacs to get a volt meter and jump cable. Ill get back to you guys very soon!
post #5 of 13 Old 04-15-2011, 03:14 PM Thread Starter
thebeast64
ok, so there is no power to low pressure switch at all. from looking at this diagram, im thinking its got to be the clutch relay because when i engage the clutch with a test lead, it works.
post #6 of 13 Old 04-15-2011, 04:08 PM
AZ94YJ
Maybe... When you hooked up the jumper did it blow cold? Did you check pressures with a set of guages? Not saying it couldn't be the relay, but it's usually something simple...
AZ94YJ is offline
post #7 of 13 Old 04-15-2011, 04:22 PM Thread Starter
thebeast64
It blew REALLY hot....
post #8 of 13 Old 04-15-2011, 05:44 PM
AZ94YJ
Yeah there isnt any freon in it... You need to charge it, you'll need to jumper the clutch and charge it... That should bring the pressure up enough to allow the low pressure switch to close and energize the clutch... That is pretty common... You may want to charge it with that freon that has the dye in it too in case there is a leak you'll be able to find it...
AZ94YJ is offline
post #9 of 13 Old 06-06-2013, 02:57 PM
GBE355
i know this thread is kinda old but i have a yj that has propper refridgerant pressure and blows cold when the pressure switch is bypassed... replace the switch today assuming that was the problem and im back to square one. The clutch wont engage! any ideas of what else my problem can be?
GBE355 is offline
post #10 of 13 Old 06-06-2013, 04:56 PM
jeepinjames20
jeepinjames20's Avatar
Part of the problem could be you're running with doors and a top in SoCal.
_/|,[____],
--...-L-[]IIII[]-
.^._.^.-===-
()_) ()_)-o-)_)
JEEPen James
Firefighters Jeep Club
Build...Run...Break...Repair...Repeat...
jeepinjames20 is offline
post #11 of 13 Old 06-06-2013, 08:04 PM
pasinbuy
I am not a ac guy but, how cold does it run? If just a little cold you could just need Freon.
pasinbuy is offline
post #12 of 13 Old 05-31-2017, 08:40 AM
Dake
Dake's Avatar
Anyone now what puller is need to pull the clutch I'm trying to find a new clutch for the A/C
Waiting on my Rough Country lift to sag!
Dake is offline
post #13 of 13 Old 06-01-2017, 06:45 PM
Louie4
Maybe a 3 jaw? Go to Autozone and rent one. They should be able to help...maybe.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
clutch not engaging mmaverick88 TJ Wrangler Technical Forum 1 12-21-2009 03:16 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
Clutch not engaging all the way YJ_95 YJ Wrangler Technical Forum 10 05-31-2008 06:10 PM
Clutch engaging val92wrangler YJ Wrangler Technical Forum 1 04-23-2008 03:22 AM
Clutch not engaging! >:-/ 89' YJ Junker YJ Wrangler Technical Forum 2 02-06-2007 02:26 AM
