YJ built on a TJ frame? - JeepForum.com
post #1 of 5 Old 07-28-2009, 11:57 AM Thread Starter
walkingcrow
I recently bought a 91 YJ but the frame is rotted and has been poorly repaired previously to the point that I am thinking about replacing the frame altogether. I have found a TJ frame but I don't know if I can swap it over or not. I know one is leaf springs and one is coils. Any ideas?
Thanks
WC
walkingcrow is offline
post #2 of 5 Old 07-28-2009, 12:08 PM
timatoe
timatoe's Avatar
It could be done, but it's not going to just go right on, there will be a lot of work involved.
timatoe is offline
post #3 of 5 Old 07-28-2009, 04:12 PM
dukegnarley
around here you can find yj frames for around $250. swapping a yj body onto a tj tub is going to be more work than it's worth.
Unlimited Length YJ "Sasquatch"
Renix 4.0
AW4 swap with
= DONE
dukegnarley is offline
post #4 of 5 Old 07-28-2009, 04:29 PM Thread Starter
walkingcrow
Thanks for the info. I will keep looking for a yj frame.
post #5 of 5 Old 07-28-2009, 04:30 PM
Canfourjeep
yj body on a TJ frame
Not that hard. Several have done it and it came out great. The back four mounts line up. The front mounts will need to be moved about 3 CM. The gas tank works if you use flex hoses. You might have to trim the inner front fenders a bit to clear. I have a TJ frame in my back yard that I am in the process of doing this swap. I have done a lot of measuring and I think this will be an easy swap. There is a Lincoln here on a F250 frame and that was not that hard. Anything can be done it just depends on how bad you want it.
Canfourjeep is offline
bestop frame better than stock soft top frame? goose142004 YJ Wrangler Technical Forum 10 11-24-2009 12:34 PM
jeeps are built not bought right??? so i built mine more teejmcd YJ Wrangler Technical Forum 22 11-20-2009 11:46 AM
rigid frame or flexible frame blackcat471 TJ Wrangler Technical Forum 8 08-12-2009 02:18 AM
swap wrangler frame with cj7 frame midgetdog YJ Wrangler Technical Forum 7 04-15-2009 10:58 AM
Tow hitch: Frame mounted or bumper built-in? Shinner YJ Wrangler Technical Forum 10 08-30-2003 09:15 AM
