YJ build what now? - JeepForum.com
post #1 of 9 Old 07-22-2008, 09:42 PM Thread Starter
88YJeep
YJ build what now?
Ok I bought my Jeep in Nov 07 and have since installed a 4" lift ,33" boggers and bumpers. now that It looks the way I want I'd like it to function and perform the way I want too . she's got stock axles and drivetrain,so ... well let's go this way first..... Is the 30 or the 35 the week link I've heard both and want to swap sooner probably later as funds are short so what shoul I be aiming for first? I've got 3.07 gears which suck hard core and no sye . what can I do on a little...tiny budget?
88YJeep is offline
post #2 of 9 Old 07-22-2008, 09:47 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
SYE & XJ shaft shouldn't run you more than about $400 or so. You could buy the parts a little at a time to spread things out a bit on your budget.
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 9 Old 07-22-2008, 09:55 PM Thread Starter
88YJeep
The vibes not so bad it's the gearing thand the axle strength that bothers me
88YJeep is offline
post #4 of 9 Old 07-22-2008, 09:55 PM
hoki06
Could look for a D30 out of a 4cyl YJ that has 4.10 gears, then find an 8.8 with 4.10s to match. If you want to go further you could swap in TJ shafts into the D30 and do a block off plate to get rid of the vaccum. Then just get the brackets and everything for the 8.8. Upgrade gears and rear axle at the same time.
hoki06 is offline
post #5 of 9 Old 07-22-2008, 10:12 PM
Brandon_YJ
1987 YJ Wrangler
Nutter bypass.
4.0 head swap.
Team rush upgrade.
All three of those can be done for under $400 and the performance gains are remarkable!
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #6 of 9 Old 07-22-2008, 10:37 PM
hoki06
Originally Posted by Brandon_YJ View Post
Nutter bypass.
4.0 head swap.
Team rush upgrade.
4.0 head swap for under $400??? How? From what I've read it costs a good bit more
hoki06 is offline
post #7 of 9 Old 07-22-2008, 10:38 PM
xeastend
I've heard the D30s can hold up to 37s with no issues, and the turdy five, you should be okay with depending on how you drive/wheel, but I would definately swap in for an 8.8 if you get the chance.
White 90 YJ...Soft/Hardtop, 31" BFGs, 3.5" lift, Rebuilt 4.2L, Weber 34/34, Herc'd
LOOKING FOR 4cyl axles F/R, 4.10s, will trade for my 3.07s complete
Also need 16x8 rims with less backspacing
xeastend is offline
post #8 of 9 Old 07-22-2008, 10:48 PM
Brandon_YJ
1987 YJ Wrangler
Call a salvage yard or hit up Craigslist. You should be able to get the assembled head and exhaust manifold for less than $150.
On ebay you can get a remanufactured head with the holes welded up for $400 I believe. But if you can do the work yourself you can do the entire thing for under $200.
in a (text only)
post #9 of 9 Old 07-23-2008, 12:23 AM
Piet
Ditch the 35 first... try a Dana 44, or a Ford 9"
- Peter ----------- Canadian Jeep Club Member
- 3.8L V6, 6 Spd Manual, RockTrac with Dana 44's on 32's. Mostly stock for now...
- 350 TBI, NV4500, Dana 300, Detroit Locked Dana 44, Spooled 9", SOA, 37" MTR's
- 4 Cylinder Stocker on 31" Kuhmo MTs
Piet is offline
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 01:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 10:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 11:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 03:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-28-2006 12:05 AM
