YJ Bright light quick fix - JeepForum.com
post #1 of 12 Old 08-08-2013, 01:26 PM Thread Starter
ReddDawg
Is there a quick and easy way to rig up a bright light switch?
I rarely drive the jeep after dusk. I have never needed my brights but now I need to get it inspected and one of the things we must have here in Mississippi is bright lights. I could pull the steering wheel off and go through all of that but thought someone may know something quick and easy to get me through inspection until I have time to disassemble the column.
and yes, it is the switch. Does not take much to pull the yoke out which means you have to be careful using the turn signals and wipers. When you pull it back it will come all the way under the steering wheel and never click.
Thanks
It's not restored. It's renewed!
94 Wrangler SE 4.0 5 speed
ReddDawg is offline
post #2 of 12 Old 08-08-2013, 02:52 PM
superj
Nah, no one does
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 12 Old 08-08-2013, 02:54 PM
mike_breaker_5
there is a super easy way. my column is jacked. so i just put in a foot switch for my high beams. less than $20 and about 30 min of work.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #4 of 12 Old 08-08-2013, 02:57 PM
superj
Doh, forgot about that super easy way, dangit. That I'd a great way
superj is offline
post #5 of 12 Old 08-08-2013, 03:03 PM
mike_breaker_5
get one of these...
http://www.ebay.com/itm/Standard-Mot...f1aad7&vxp=mtr
and one of these.
http://www.ebay.com/itm/SMP-STANDARD...a2c248&vxp=mtr
it's easy to wire up.
post #6 of 12 Old 08-08-2013, 03:52 PM
XJ93
Have you checked the adjustment on the switch itself on the lower column? If the screws that hold it in place have come loose, it may have allowed the switch to slide down, so your stick would have to travel farther and may not even be pushing down far enough.
XJ93 is offline
post #7 of 12 Old 08-08-2013, 03:56 PM
claudiaj941
Yeah it is easy
claudiaj941 is offline
post #8 of 12 Old 08-11-2013, 11:31 AM
Hilblee
Ive got the foot switch and its easy to hook up---3 wires
Hilblee is offline
post #9 of 12 Old 08-12-2013, 08:57 AM Thread Starter
ReddDawg
Well. We made it through inspection. However I have very little control over the wipers, brights must be held to work and if you hit the turn signal quick you get to pick the stem up. (it broke out of the housing) So. I need a new stem and whatever housing it goes into. If this is part of the brights fix I guess I am on a crash course to fix it all but I would love some insight into what wires need to go to a floor switch.
ReddDawg is offline
post #10 of 12 Old 08-12-2013, 09:08 AM
crazymon01
crazymon01's Avatar
Mine started doing that a few years ago when I was replacing switch. Somehow I had a squiggly metal rod in there (sorry can't tell ya name of it) came out and I couldn't figure out how it went back in there. So now my brights are my 6 h4's mounted on my light bar switched on with toggle switch...
4.0
I6
ARB snorkle
307 -> 411 gear swap
lock rite locker on the dana 35
33 x 12.50 Mickey Thompson radial MTZ
4.5" Rubicon Express heavy duty Suspension Lift
currie boomerang shackles
8,000 lbs. Winch
bikini top
tonneau cover
pictures??
crazymon01 is offline
post #11 of 12 Old 08-12-2013, 02:08 PM
Hilblee
There is a black 3 pronged connection under your dash at the steering column, The three female connectors are the exact same as the three male connectors on a foot switch. Run 3 wires from the connector to the foot switch and mount the switch to the floor.
Ive owned 74, 75, 76 and 79 CJ-5s. 76 J10 (prob the best jeep ever) 89 YJ (current) and a 98 TJ. I consider all of them "Money Pits" Always throwin money at em whether they need it or not!
Hilblee is offline
post #12 of 12 Old 08-12-2013, 02:09 PM
Hilblee
Deleted
Hilblee is offline
