YJ brake lines - Page 2 - JeepForum.com
post #16 of 20 Old 05-08-2012, 03:50 PM
mrdeath2000
if this is a Daily Driver, then you will need to bleed your brakes after each line. If it is NOT, then you can do a section at a time just make sure you dont deplete the master cylinder or you have to pull it and bench bleed it.
If you are doing this a section at a time for a Daily Driver, look into a set (front and rear) of SPEED BLEEDERS. I bled all 4 of my brakes, by myself in 10-15 minutes. The stock fittings/nuts at the ends of the lines are 3/8" (not sure what size going into master cylinder, id have to check at home). The line diameter, I am not sure.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #17 of 20 Old 05-08-2012, 04:11 PM
jbolty
jbolty's Avatar
Before doing anything measure each segment and make a map for where each goes. You can get pre cut/pre flared lines in many many different lengths so there will be no need for flaring. The long run from fron to back will need a union joint in the middle because you won't find a piece long enough already flared. Also, the one running to the right front wheel is easier to get in place if you make it in two place and join it.
Take out one piece, use it as a template to bend the new one, install, proceed to next section.
When bending go slow to avoid kinking and invest in a $10 bending tool.
The whole job should not take more than 2-4 hours then bleed the entire system until clean fluid is throughout.
jbolty is offline
post #18 of 20 Old 04-25-2014, 09:53 PM
marcello23
Where do the hardline brake extensions go? Do they mount to the caliper and go up towards the frame or they bolt up in the frame bracket and go down towards the caliper? Thanks!
marcello23 is offline
post #19 of 20 Old 04-25-2014, 09:54 PM
marcello23
I'm using the hardline extensions that come with the RE 2.5" lift
post #20 of 20 Old 04-25-2014, 10:01 PM
Opihi59
from here it gets rough
Opihi59's Avatar
??? They can only go one way. There is a square end the banjo bolt goes thru, and the other end joins into the hard brakeline up on the frame rail. It should be obvious unless I am totally missing something. Perhaps if you post up a photo of your extensions it may be easier to figure out, because I must somehow be missing something.
Resurrection, and Easter is already behind us.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
brake lines , extensions , lift , YJ
extended brake lines - using YJ lines with TJ ABS?? tucanbob TJ Wrangler Technical Forum 11 07-27-2011 06:51 PM
After replacing calipers and rubber brake lines, my brake is still stuck! Dmcastino TJ Wrangler Technical Forum 23 06-25-2009 11:21 PM
Hard Brake lines(not soft lines) Nonya TJ Wrangler Technical Forum 0 09-04-2007 06:33 PM
Stock brake lines don't bolt up to Van's Big Brake kit Red_ TJ Wrangler Technical Forum 6 06-17-2007 10:11 PM
8.8 swap brake problems. How did you run your brake lines? quitelifted TJ Wrangler Technical Forum 5 10-19-2006 09:16 AM
