YJ Bolt Pattern - JeepForum.com
post #1 of 7 Old 04-03-2009, 04:07 PM Thread Starter
zeke6785
YJ Bolt Pattern
I looked in the FAQ and couldnt find it what is the bolt pattern for a 1990 YJ
2012 Wrangler
35" Pro-Comp Xtreme M/T
3" Full Traction Lift
Smittybilt Stinger
zeke6785 is offline
post #2 of 7 Old 04-03-2009, 04:07 PM
Goobersbro
5x4.5 .
My marshmallow build
Goobersbro is offline
post #3 of 7 Old 04-03-2009, 04:08 PM
buickgnx88
Or 5x114.3 if you need metric.
buickgnx88 is offline
post #4 of 7 Old 04-03-2009, 04:24 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
It's in the YJ Wrangler Factory/Stock Specs link near the top when you open up the FAQ thread, where the dimensions area is:
http://www.jeepforum.com/forum/f12/yj-wrangler-stock-specs-563403/
Joe Dillard is offline
post #5 of 7 Old 02-12-2011, 09:50 AM
speedbump94
is the bolt pattern the same on all yj models?
/l ,[____],
|-- -L--[]lllllll[]-
()_)-()_)==O=)_)
speedbump94 is offline
post #6 of 7 Old 02-12-2011, 09:58 AM
dadstoy
The bolt pattern is the same on all "stock" YJ axles.
dadstoy is offline
post #7 of 7 Old 02-12-2011, 10:00 AM
speedbump94
thanks, ive been curios about that.
/l ,[____],
|-- -L--[]lllllll[]-
()_)-()_)==O=)_)
Bolt pattern 5 x 135 will it fit richnev JK Wrangler Technical Forum 1 07-23-2007 06:51 PM
tj bolt pattern?? alex71 TJ Wrangler Technical Forum 5 07-12-2006 01:52 PM
TJ bolt pattern UTmike TJ Wrangler Technical Forum 4 07-09-2006 07:29 AM
bolt pattern surfgod04 TJ Wrangler Technical Forum 2 11-27-2005 01:47 PM
99 TJ Bolt Pattern? Supercharged99TJ TJ Wrangler Technical Forum 3 11-20-2002 09:05 PM
