yj bogs out as it pleases - JeepForum.com
post #1 of 1 Old 06-09-2010, 06:47 PM Thread Starter
kxlspike115
ok so my YJ had a cracked carb and i replaced it with a Weber 34/34
the jeep seemed to run pretty rough after the new carb was installed still so I adjusted the timing, changed the plugs, wires, distrib cap, put in an inline fuel pressure regulator and set it at 3.5 psi, new fuel filter, and a new exhaust without a cat just straight pipe to muffler. Also, all the emmissions and such are nixed.
the jeep is a little hard to start usually crank it a few times stop then start again and with a little gas it'll start up and it idles around 1600 and then as it warms up drops down between 700 to 900 rpm's. It drives ok in first and second but if you go into third and get over like 2200 rpm's it starts to bog out and die. It is extremely tough to make it up hills and I have to downshift to second or even first sometimes to slowly try and get up the whole thing. On flat ground it runs better but still seems to slowly bog out if you really get on it and open up the throttle more than half way in third or higher.
this is my daily driver and I cant have it barely running I have tried and tried to get it to work right but I am out of idea's please help!
kxlspike115 is offline
carburetor , weber
TJ bogs down when AC kicks in. bashepard TJ Wrangler Technical Forum 2 06-01-2010 12:30 AM
4.2 6CL bogs low or cuts off chittybangbang YJ Wrangler Technical Forum 0 08-09-2009 12:49 AM
Went though the Mud Bogs lilred4x4 JK Wrangler Technical Forum 4 08-04-2008 04:15 PM
Jeep bogs down JPM TJ Wrangler Technical Forum 10 08-19-2007 02:40 PM
bogs down myheapofjeep YJ Wrangler Technical Forum 3 06-04-2003 11:47 PM
