YJ Body mount locations - JeepForum.com
post #1 of 7 Old 02-16-2009, 07:43 AM Thread Starter
mark12010
I have a 1" body lift for my yj and there are 11 mounts I see 3 on each side under the doors 1 on each side by the rear bumper and 1 in the center of the front. Now for the really dumb question. Where are the other 2 ?
mark12010 is offline
post #2 of 7 Old 02-16-2009, 07:48 AM
Matt_vs_YJ
IIRC, they're under the bed area of the tub, near the rear shock mounts.
Matt_vs_YJ is offline
post #3 of 7 Old 02-16-2009, 07:51 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
they are up near the shock mounts. Almost above the gas tank.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 7 Old 02-16-2009, 08:48 AM
CheapSunglasses
2007 XK Commander
There are 11 as follows:
1 under the radiator in the center
3 along each side of the tub under the rockers (6 Total)
2 at the very rear of the frame rails at the tub corners
And finally, 2 located above the shocks
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline
post #5 of 7 Old 02-16-2009, 08:49 AM
trucknut
...one in very front of jeep under grill
...six (3 per side) under middle section of jeep below the door
...two (1 per side) on rear crossmember supporting front of gas tank
...two (1 per side) at very back of jeep
1994 Jeep YJ 2.5
My Save the YJ from the junkyard project...
2001 Toyota Tundra TRD
trucknut is offline
post #6 of 7 Old 02-16-2009, 11:15 AM
rrisher
1987 YJ Wrangler
when you start doing the lift and unbolting the tub, you can't miss them! But, there near the tank!
rrisher is offline
post #7 of 7 Old 10-12-2016, 06:55 AM
UPJeep3
Mounts by rear shocks
Staying on the same topic of these two bushing on a YJ, how do they go in? All of my others I've put in dropped right into place, but both of them are really tight. I can't work them in by hand, I slightly rounded off the leading edge of the bushing, and even lined them up and slowly dropped the body back down. There seems to be some type of sleeve, but to me it looks like it should stay. Nothing looks like it was left behind from the old bushing. I did have to pry the old ones out. Thanks
UPJeep3 is offline
Body Mount Bolt Locations (For BL) - Detailed Write-Up W/ Pix CheapSunglasses YJ Wrangler Technical Forum 107 06-20-2016 03:37 PM
Lets see you CB mount locations N2rock JK Wrangler Technical Forum 35 02-04-2010 07:56 PM
TJ body mount locations (pictures?) rikkards TJ Wrangler Technical Forum 3 06-15-2009 03:55 AM
Satellite radio / GPS mount locations? TellarHK YJ Wrangler Technical Forum 7 10-19-2008 12:00 PM
11 Body Mount Locations BRad704 YJ Wrangler Technical Forum 4 01-05-2006 04:00 PM
