yj body lift problem - Page 2 - JeepForum.com
post #16 of 20 Old 03-31-2010, 10:55 AM
MJMPC
Would something loke this work?
Original Replacement Parts 5456734 - Body Mount Washer for 76-86 Jeep® CJ - Quadratec
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #17 of 20 Old 03-31-2010, 01:22 PM
Que89YJ
The ones for the YJ are mushroomed to keep the bushing centered and its anone piece sleve. Its different in some ways, but that doesnt mean it won't work.
Jeep Wrangler accessory and original Jeep parts and accessories - only from Jeepsareus.com
is a direct replacement. They are really good with the customers and if you only knew what an azz I can be at times you'd understand what a huge compliment it is to them.
Que89YJ is offline
post #18 of 20 Old 03-31-2010, 06:30 PM Thread Starter
wayno32m
well i guess i was`nt the only one who thought this was a complete kit,this is gonna be an expensive inch!!!!!!!!!!!!! another lesson learned
wayno32m is offline
post #19 of 20 Old 03-31-2010, 07:39 PM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
go find a local auto salvage and bring breaker bar and extensions and a BFH.
break the bolts under a donor body, use bfh to knock the bushings out sideways, steal the mushrooms.
cheap.
Axles and bolts and springs....Oh My!
My Build Thread --->>>
Not my write up, but now one of my jeeps losing a BA and gaining an AX->
hotelconucc93 is offline
post #20 of 20 Old 04-01-2010, 06:23 AM
Area.3.Fiftyone
CJ's, YJ's and TJ's are nearly non existent in the salvage yards around here and when I do find them, you have to be quick or else they are stripped to nothing in no time.
Plus the road salt used in Pa kills them.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
TJ body lift/mml problem whiteguyjames TJ Wrangler Technical Forum 39 05-31-2015 09:18 AM
Need advice on body lift problem cyberpvnk Wrangler General Discussion 3 05-10-2009 08:39 AM
Body Lift Problem JeepPirate TJ Wrangler Technical Forum 3 01-24-2008 10:25 PM
Body lift problem happycamper TJ Wrangler Technical Forum 5 12-17-2006 07:33 PM
New body lift...now problem Mr.Alllthat TJ Wrangler Technical Forum 2 07-27-2006 09:54 AM
