yj body lift problem - JeepForum.com
post #1 of 20 Old 03-30-2010, 05:25 PM Thread Starter
wayno32m
wayno32m's Avatar
hey guys i`m a nubie here ,my problem is i bought a daystar 1"lift and after fighting with most of the bolt`s (only broke one!!) come to find out that the stock steel insert`s i`m supposed to reuse are in pretty bad shape, anyone know where i can buy just those? thanks for any help!!!!!!
wayno32m is offline
post #2 of 20 Old 03-30-2010, 05:29 PM
ZeroGravity
They usually come out pretty rusty. Some dealers sell them for a couple dollars each but apparently an ebay seller sells them for under $5 each. I saw this topic a couple weeks ago, so I would try using the search function. I believe it's called a crush sleeve, but it may be known as something else.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #3 of 20 Old 03-30-2010, 05:41 PM
moonshinefuel
I know this has come up before many times. I think it is one of those things where you have to fabricate replacements. But maybe you can buy factory, did you try a dealership?
moonshinefuel is offline
post #4 of 20 Old 03-30-2010, 05:42 PM
ZeroGravity
Dealerships can get them and you can find them on Ebay.
91 YJ
98 XJ
2 door love
post #5 of 20 Old 03-31-2010, 04:04 AM Thread Starter
wayno32m
wayno32m's Avatar
Thanks guy`s, but does anyone know what these are called i`m not having any luck in the search
wayno32m is offline
post #6 of 20 Old 03-31-2010, 04:33 AM
Jabo
I called an oem parts supplier, they had them, but at $7.50 each. Multiply that by 11 plus shipping and your over $90. I actually called Daystar and complained to them about false advertising. I ordered the Daystar kit because they said that the metal sleeve was included. Well, all is included is a 7/8" sleeve to make up the difference. No where in their description does it state you that you have to use your sleeves. I have seen other kits that state that.
Needless to say, they did nothing about it...
Jabo is offline
post #7 of 20 Old 03-31-2010, 04:42 AM
parkerm26
is it the mushroom lookin sleeve? i believve i saw that in this thread or something like it. post #117 http://www.jeepforum.com/forum/f12/t...13/index3.html
93YJ 350-465-205, D60 and 14 Bolt, 40's http://www.jeepforum.com/forum/f22/yj-rustoration-1327569/
parkerm26 is offline
post #8 of 20 Old 03-31-2010, 06:47 AM
Jabo
Yes it is.
Jabo is offline
post #9 of 20 Old 03-31-2010, 07:17 AM
rinking
I just put this body mount/1"lift on mine this winter and it had all the sleeves! I think I bought it through 4wd hardware. I ordered Daystar but if I remember right, the box said Prothane or something like that!
rinking is offline
post #10 of 20 Old 03-31-2010, 07:19 AM
parkerm26
anyone have a part number for this? or where to get it? (napa, advanced A P?) i have a 1" daystar ready to put in but i've been pbblasting. now that i learned this i feel like ill be missing these. i cant even get some mounts out...
post #11 of 20 Old 03-31-2010, 07:20 AM
Area.3.Fiftyone
Well, that really sucks. My daystar kit is on it's way and that's one of the reasons I chose their kit was because it is supposed to come with new sleeves.
I hope mine aren't too bad when I try and get them apart.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #12 of 20 Old 03-31-2010, 07:23 AM
parkerm26
me too. everything needs replacing and it says it replaces everything. mushroom sleeve part number?
post #13 of 20 Old 03-31-2010, 10:29 AM
Que89YJ
Here is a link: Jeep Wrangler accessory and original Jeep parts and accessories - only from Jeepsareus.com
Call them. They have them in stock. They aren't listed on the page but they are very inexpensive. I think they are $5 or $6 a piece.
Que89YJ is offline
post #14 of 20 Old 03-31-2010, 10:41 AM
remmons
I clicked on the link and began to drool on my keyboard. There are a lot of parts on there that I wondered where I was going to get them from otherwise. My part(s) are unrelated to this thread, but the link was still very helpful for me. Thank you.
Robert.
remmons is offline
post #15 of 20 Old 03-31-2010, 10:49 AM
hotelconucc93
hotelconucc93's Avatar
2010 YJ Wrangler
I had some stuck mushrooms as seen in the above mentioned rebuild thread.
To get them out I used a rubber mallet while loose hold on the old body mounts. Some came out easy...some were SOBs.
Answer to get them out is to use heat on the inside of the mushroom sleeve and beat them out when the rubber starts smoking. Two or three of mine were rather rough, but I decided to neated them up and use plenty of anti-sieze.
Axles and bolts and springs....Oh My!
My Build Thread --->>>
Not my write up, but now one of my jeeps losing a BA and gaining an AX->
hotelconucc93 is offline
TJ body lift/mml problem whiteguyjames TJ Wrangler Technical Forum 39 05-31-2015 09:18 AM
Need advice on body lift problem cyberpvnk Wrangler General Discussion 3 05-10-2009 08:39 AM
Body Lift Problem JeepPirate TJ Wrangler Technical Forum 3 01-24-2008 10:25 PM
Body lift problem happycamper TJ Wrangler Technical Forum 5 12-17-2006 07:33 PM
New body lift...now problem Mr.Alllthat TJ Wrangler Technical Forum 2 07-27-2006 09:54 AM
