YJ axle u-joint replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > YJ axle u-joint replacement
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDSPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread Yesterday, 05:00 AM   #1
bdserv
I will be changing out the axle u-joints on an 89 YJ with the CAD on the passenger side.
My questions is, do I need to do anything with the CAD in order to remove the passenger side axle, or can it just be removed and then re-installed the same as on a typical TJ?
bdserv is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:58 AM   #2
Mark05059
if your not removing the inner axle then you dont need to touch the CAD.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:19 AM   #3
johnboy68
HIP2BSQR
johnboy68's Avatar
And as always, be careful removing and replacing the axle shaft to not damage the seal. In my opinion, it's the hardest to replace.
Skip a kit like you skipped other things. Don't be a dork.
johnboy68 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:42 PM   #4
bdserv
OK - thanks for the feedback guys. Will definitely give that seal some extra special care.
Unread Yesterday, 05:52 PM   #5
adiubald
I believe in 2wd the CAD connecting collar and fork are shifted onto the outer shaft. In 4wd the collar is pushed inboard and connects the intermediate and outer shaft. In other words, when you pull the outer shaft, the collar will be displaced. When you re-install the outer shaft, I would open the CAD to make sure the collar is good to go.
adiubald is offline   Reply With Quote Quick reply to this message
