YJ Axle swap....kinda? - JeepForum.com
post #1 of 19 Old 06-28-2012, 05:19 PM Thread Starter
DoozerPeej
I have the chance to buy a front HP D30 and a Dana 35 rear (barf) that already have 4.88 gears, the HP D30 has had TJ shafts put in, lock-rite locker, and also comes with all brakes, rotors, calipers, and the entire steering set up. The D35 has a Detroit Locker in the rear, also set up for 4.88 and has the disc brake conversion put on. It is set up for a YJ and I am very tempted. I have same axle set up but with 3.07 gearing, and open differentials front and rear, front axle is still the two piece on passenger side. I have 33" tires and do not hop the wheels as I baby everything I own. I know the D35 is a ticking time bomb, but i'm not too worried about it. What would you pay for the two axles with everything included? Quick reply would be great
DoozerPeej is offline
post #2 of 19 Old 06-28-2012, 05:31 PM
jbolty
jbolty's Avatar
Maybe $500 or so
A D30 with stock 4:10 gears for about $200 here. Gears and locker would cost about $500 to install new but they are used now. TJ shafts are about $20 at any junkyard. I assume you already have the brake parts and steering from your current axle so there's little value to you there. The D35 really has no value even with the locker.
What are they asking.
jbolty is offline
post #3 of 19 Old 06-28-2012, 06:39 PM
USMCBuckWild
If you've never driven on the street with a Detroit in the rear, you'll be in for a surprise. I bought a similar setup when my second Dana 35 went boom and I hated it.
Drivin a Detroit on the street takes a combination of balls, delicacy and stupidity. In a Hotrod its one thing, a Jeep is quite another....
USMCBuckWild is offline
post #4 of 19 Old 06-28-2012, 07:36 PM
MLJeeper
MLJeeper's Avatar
Im going to delete my remarks and see where this goes.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #5 of 19 Old 06-28-2012, 07:52 PM
fratis
fratis's Avatar
off topic. please reread question...
let me help:
-insert meaningless out-of-place political diatribe-
fratis is offline
post #6 of 19 Old 06-28-2012, 07:58 PM
BlueRubiconrich
you are looking at buying someone elses junk. Build your own dana 44 front and rear.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #7 of 19 Old 06-28-2012, 10:16 PM
fratis
fratis's Avatar
no you gave a personal opinion that had nothing to do with the question. not "tech" related in any way.
fratis is offline
post #8 of 19 Old 06-28-2012, 10:33 PM
jbolty
jbolty's Avatar
Please no bickering; there's been plenty of that in this section of late.
jbolty is offline
post #9 of 19 Old 06-28-2012, 10:33 PM
linusb
I'd pay 200-250 for front and would maybe give 50 for rear, that would be only in the case that I needed a quick and temporary swap (talking about D35)
Do you have 4 cyl or 4.0?
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #10 of 19 Old 06-28-2012, 10:36 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
My apologies.
I'll take it all down
Luck Favours The Prepared
Anticanman is offline
post #11 of 19 Old 06-29-2012, 03:25 AM
USMCBuckWild
I wasn't trying to go off topic but simply relate my own experiences with a Detroit. I wouldn't suggest using the Detroit in a D35 as a street vehicle. To someone not accustomed to driving one, they can be very dangerous.
As previously stated, $250 for the front and I wouldn't bother with the rear. To me it makes more sense to spend money on something that will last and be worthwhile. If you need a rear tk hold you over while you are building one, may e pick up the D35 for $100. But don't plan on it lasting very long with the Detroit and 33s.
Total I would offer: $300
That more on topic?
post #12 of 19 Old 06-29-2012, 10:26 AM Thread Starter
DoozerPeej
Hey thanks for the replies, my YJ has the 4.2 and ax15. This jeep is not a daily driver by any means. It sees about 5 miles of asphault and then its all dirt. I live in utah and so there are mountains in every direction of me. I do not do moab type rock crawling, or mudding. its mainly just going up old mining trails and mountain access roads. I just hate my 3.07 gears and figured that $500 for everything is a pretty good deal. I know everyone hates the D35 but I haven't had any issues with mine, granted it has an open diff. I am a full service auto mechanic and work on lifted jeeps all day long and have yet to do anything other than an axle seal here and there on a D35. I have seen more issues with the Grand Cherokee D44a than any other axle, of course not counting all the Yota axles we rebuild
post #13 of 19 Old 06-29-2012, 10:32 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
$500 is a pretty fair price considering there is an option to resell the Dana 35 if you wanted a stronger axle to replace it. I would say its a good start but it's only worth however much you're willing to pay for it based on how badly you want it.
post #14 of 19 Old 06-29-2012, 10:58 AM
trailrider787
I agree, $500 is fair price. I did almost the same thing. Bumped up to 33" tires with 3.07's and decided I needed some different gears. I paid $100 for a set of 4.10 d30 and d35 that came out of a 4cyl. Bolted them in for the time being to keep wheeling. Bought some Aussie lockers front and rear for good deal, and held up well with light throttle usage offroad. I did have a set of spare shafts for the d35 just in case though. I eventually found a ford 8.8 and swapped it in the rear, but the D35 with the locker allowed me to keep wheeling and keep up with my buddies while I built the 8.8. I am currently going to sell both front and rear Dana's with Aussies for $300 to a family member who doesn't plan on wheeling to much.
With that being said, $500 is good deal I think for 4.88's and you can resell them later.
trailrider787 is offline
post #15 of 19 Old 06-29-2012, 05:28 PM
Castr8r
$500 is a good price- real good! Put a truss on the D-35 if you think it may be shakey, but I can tell you from my personal experience that the D-35 is not the total boat anchor it's made out to be. It should do you well. Carry some spare shafts as back-up, or go with alloy shafts.
I've been throwed out of a carwash- too much mud!
I've done bodywork useing a winch, a tree, a prybar, and a BFH!
Now, my wild oats have turned to prune juice and all-bran...
Castr8r is offline
help stock engine swap, kinda alspayne TJ Wrangler Technical Forum 3 05-29-2012 10:59 AM
Some kinda Vacume bypass to get kinda like front locker? 2muchfun YJ Wrangler Technical Forum 14 10-28-2011 11:38 AM
Rear axle center position after wreck...kinda long Tufftoy JK Wrangler Technical Forum 4 07-05-2009 08:42 AM
Lookin for a new rear axle and kinda wonderin what would be good swaps? cb19950 TJ Wrangler Technical Forum 11 11-09-2006 08:51 PM
ranger 8.8 axle swap???? (kinda long) tcf26 YJ Wrangler Technical Forum 8 03-26-2003 11:34 PM
