YJ axle swap - JeepForum.com
post #1 of 8 Old 09-21-2009, 04:12 PM Thread Starter
hesserdude07
YJ axle swap
I have a 1993 YJ. 2.5 w a 5spd. Stock axles. 1" body and 2" shackels.
I just got my hands on a set of Dana 44s from a Jeep Wagoneer. I just need some input on swap'n them into mine. I know i need to regear. I run Brand new 31's Swamper TrXus MT. Looking at going to 4.88s and spool rear. Unlocked front for now. Any help or suggestion would be great!!
hesserdude07 is offline
post #2 of 8 Old 09-21-2009, 04:34 PM
griggs762
If your going to use it on that street at all i'd think twice about a spool in the back. You might want to go with a locker instead.
99 TJ
91 YJ
griggs762 is offline
post #3 of 8 Old 09-21-2009, 06:05 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Excellent info here:
Izzy Build
Joe Dillard is offline
post #4 of 8 Old 02-07-2010, 10:00 AM Thread Starter
hesserdude07
Just to update, im going with a ford explorer 8.8 exle. Axle is coming this week, and im building all all my spring brackets. Its got 4.10s and stock limited slip. I ended up welding my stock D35 and have not had 1 single issue with my 31's. Never broke... Just going to bigger tires so i dont trust the axle as i know they are junk. Did the tube fenders on front, and going to do comp corners on rear so i can go to a 35" tire and no more lift that i use now.
post #5 of 8 Old 04-10-2010, 09:09 PM Thread Starter
hesserdude07
so i did my 8.8 swap today. I got lucky, i got my stock D35 out in 27mins, working alone, NO heat or blaster... Used the MORE 8.8 axle mounting kit. AMAZING. Stick welded tubes into pumpkin with nickel rod. 220v Lincoln welder for all my brackets, and spider gears. Doing stock drive shaft and got the pinion flange off the stock Ford drive shaft. Any one know the part number for the index U joint?
wish i could put pics up....
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
post #6 of 8 Old 04-17-2010, 04:30 PM Thread Starter
hesserdude07
Finally...
swapped 8.8 with M.O.R.E. offroad 8.8 swap kit.
http://s894.photobucket.com/albums/a...0409001717.jpg
http://s894.photobucket.com/albums/a...409001717a.jpg
http://s894.photobucket.com/albums/a...410001053a.jpg
http://s894.photobucket.com/albums/a...0410001053.jpg
http://s894.photobucket.com/albums/a...0410001054.jpg
post #7 of 8 Old 04-17-2010, 06:24 PM
trippleb
4:56's would get you back close to the factory gearing on your jeep if you only going to run 31's.
-Bryon
trippleb is offline
post #8 of 8 Old 04-17-2010, 06:51 PM Thread Starter
hesserdude07
8.8 swap all done.
93 wrangler :: 0417001922.jpg picture by hesserdude07 - Photobucket
93 wrangler :: 0417001923.jpg picture by hesserdude07 - Photobucket
possible 318 swap and axle swap out of a dodge ihategp YJ Wrangler Technical Forum 8 12-20-2009 03:50 PM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 03:42 AM
Gear Swap or Axle Swap? Zazoos YJ Wrangler Technical Forum 3 06-03-2009 12:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 04:28 PM
Engine 4.3L swap and axle swap abrupt11 YJ Wrangler Technical Forum 14 02-18-2005 12:14 PM
