YJ Axle Spline Count??? - JeepForum.com
post #1 of 9 Old 08-23-2013, 09:11 AM Thread Starter
Robob69
What Spline Count will my 95 YJ D35 Rear have?
I bought an axle for it a good while back but I can't remember the spline count..
I am thinking 27 count but I am not sure..
Thanks for the help!!
Robob69 is offline
post #2 of 9 Old 08-23-2013, 09:34 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Yes, 27 spline.
Randonexplosion is offline
post #3 of 9 Old 08-23-2013, 12:43 PM
ForestJeep89
Definitely 27..one can upgrade to 30 spline for better strength and tuffer metal.
ForestJeep89 is offline
post #4 of 9 Old 08-23-2013, 08:25 PM Thread Starter
Robob69
So I could put a 30 Spline in the 27 Spline Rear end???????
Robob69 is offline
post #5 of 9 Old 08-23-2013, 08:36 PM
Randonexplosion
Deplorable
Not without more work. I'm not sure on the details, but I know that you would have to install a locker to accept 30 spline shafts. The Superior Super 35 kit comes with a Detriot, and you may be able to get an OX/ARB in 30 spline. There are no 30 spline dana 35 spider gears that i know of.
Someone with more knowledge on the subject will chime in.
post #6 of 9 Old 08-23-2013, 08:46 PM Thread Starter
Robob69
Ok... well I will just hang with my good ole D35 27 Spline setup then... Cheaper...
I Will upgrade to the Ford 8.8 someday.. But they done come in 3.07 gears so I will then have to change the front gears as well... So it will have to wait...
Thank you very much for the info..
Robob69 is offline
post #7 of 9 Old 08-23-2013, 08:48 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
8.8's do come in 3.08 gearing and you're right: the only upgrade from a 27 spline is to a 31 spline.
Luck Favours The Prepared
Anticanman is offline
post #8 of 9 Old 08-24-2013, 07:26 AM
jason280
8.8s definitely come with 3.08 gears, the first 8.8 swap I did was on a '93 Sahara using a 3.08 rearend out of a '96 Explorer.
None
jason280 is offline
post #9 of 9 Old 08-24-2013, 11:07 AM
warthog312
hmmmm not sure about that. my 8.8 is from a 2000 explorer and the axle tag, r&p, and spin test all tell me it's 4.10:1 with LSD. there's other options out there.
Click for build thread:
- 302//435//20//8.8
>>>the single greatest investment you can make for your jeep is to buy a good welder, and learn how to use it<<<
warthog312 is offline
