Yj with a aw4 tranny (vibrating in od) - JeepForum.com
post #1 of 7 Old 11-01-2013, 11:10 AM Thread Starter
lbsickboy
1986 YJ Wrangler
Hi all
recently i have swapped a jeep xj 4.0 motor en AW4 tranny over into my 87 yj,
it has a 4 incH lift kit with the 1.5inch shekels so a total 0f 5.5 inch lift.
The drive shaft front is made longer and the back is shorter
i have a sye kit with the cv drive shaft from the xj at the back,
the thing is when im driving on the highway in over drive the jeep vibrates doing about 50 mph not really bad but its very annoying, when i got to give gas it goes away when i speed increases.
also should mention the yj had A tf999 auto with a 4.2l,
so im thinking it might be the gear ratio, if im right it has the 3,55 gears.
any gear heads out there that can help out please
WANGLER 87 4.0 HO AW4
4,5 " ROUGH COUNTRY LIFT KIT, 1.5" BOOMERANG SHACKLES, 33'' BANDEN, ROUGH COUNTRY DUAL STEERING STABILIZER
lbsickboy is offline
post #2 of 7 Old 11-01-2013, 12:30 PM
SeanB95YJ
my first guess would be the rear driveshaft needs balancing (or REbalancing). sounds like you're just hitting it's "sweet spot" of RPMs for resonant vibes.
my second guess would be need of fine-tuning of the rear pinion angle
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 7 Old 11-01-2013, 01:42 PM Thread Starter
lbsickboy
1986 YJ Wrangler
yes i was thinking about the drive shaft to it was balanced for me a mate of mine did it for me ill ask him to check it over.
the rear ring pinion was ok when i had the tf999 tranny in it.
post #4 of 7 Old 11-01-2013, 02:10 PM Thread Starter
lbsickboy
1986 YJ Wrangler
Just got of the phone with my mate that balanced the drive shafts,he said the back drive shaft is balanced to a piont where its 2 tenths of a millimeter thats 0.00787401575 inches.
so that's nothing for that length of my back drive shaft, its 40.5 cm lang.
so where else could i be getting the vibes from?
post #5 of 7 Old 11-01-2013, 02:50 PM
SeanB95YJ
I wasn't talking about the ring & pinion gears... I was referring to the pinion ANGLE in relation to the transfer case output... the AW4 is a bit longer than the TF999 which changes the drive shaft/pinion angle slightly... and on top of that, you now have overdrive which changes the RPM relation between the engine and output so resonant vibrations that may have been absorbed or cancelled out before are now noticeable. you said when you give it gas it goes away.
swap/build thread:
post #6 of 7 Old 11-01-2013, 02:53 PM
SeanB95YJ
an old trick that couldn't hurt to try.... remove the driveshaft and drill a small hole in the rear tube and fill about 1/3 to 1/2 way with automatic transmission fluid, then weld the hole back up... the fluid inside acts as an additional balancer and will also help absorb resonant vibes.
swap/build thread:
post #7 of 7 Old 11-01-2013, 04:27 PM Thread Starter
lbsickboy
1986 YJ Wrangler
OK im of to my mates tomorrow and see what we can do,thanks for the tip
