YJ almost overheating - JeepForum.com
post #1 of 2 Old 06-08-2010, 07:22 AM Thread Starter
booyah93
I have a 93 YJ and lately it has been running hotter and hotter. not quite to the point that I have to turn the heat on but at about 3/4 of the guage.
The coolant level is fine.
It does not always do it but when it does, normally after a long city drive, when I turn it off, I can hear the rad and overflow going nuts for a good couple of minutes.
Could it actually be getting hotter than it is reading? Do other YJs also do this? I have had this heep for like 7 years and never noticed this before.
Thanks
4" (more like 2.5") RC lift, 2" shackle, 2" body lift
TJ flares
35" Mud Kings
8.8 sitting there waiting to go in!
booyah93 is offline
post #2 of 2 Old 06-08-2010, 07:51 AM
Que89YJ
All engines heat soak when turned off. You have all the heat and no coolant or air flow when you shut it down. Do the flush and thermostat. You should be between 195-210.
Que89YJ is offline
TJ overheating with A/C on badoosh27 TJ Wrangler Technical Forum 3 10-05-2013 01:04 PM
Why am I overheating? dogbluedrummer TJ Wrangler Technical Forum 9 04-06-2010 11:19 PM
2.5 YJ overheating --chris-- YJ Wrangler Technical Forum 32 12-06-2009 07:15 PM
Overheating jlsporty YJ Wrangler Technical Forum 6 03-12-2008 12:51 PM
overheating gwfoos YJ Wrangler Technical Forum 22 03-19-2006 07:30 AM
