Yj alignment impossible? - JeepForum.com
post #1 of 6 Old 11-06-2009, 12:47 PM Thread Starter
adhdlacrosse16
2014 JK Wrangler
i went to an alignment shop and they said they couldn't do it because of worn linkage. I am in the process of buying parts but hava a question before i drop the cash. i cant find what exactly i need to order. i currently have parts 12, 13 and 16 in my garage (see 1987-1995 Jeep® Wrangler YJ Steering Replacement Parts: Jeep® Steering Column Shaft, Jeep® Column Bearing Kit, Jeep® Pitman Arm, Jeep® Power Steering Pump, Jeep® Tie Rod Assembly, Jeep® Steering Knuckle, Jeep® Ball Joint Kit. - Quadratec) <diagram i am referring to and need to know if i need to get a whole new drag link or if it possible to replace the passenger side end link or do i have to buy a new drag link.
99' WJ... tank raise mesh grill homebrew cai
magnaflow 11226, banks header, bb sittin on 31s
adhdlacrosse16 is offline
post #2 of 6 Old 11-06-2009, 12:54 PM
TheRealOldjeep
The only alignment you can do on a YJ is toe-in. A monkey with a piece of string and a tape measure can do that, I wouldn't pay good money at a shop.
#14 has the rod end built in, so you have to replace the whole piece.
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #3 of 6 Old 11-06-2009, 12:54 PM
jbolty
jbolty's Avatar
you can get ends for the drag link and for one tie rod end, the other end is the full tube replacement (looks like 14). not overly expensive to replace it all yourself.
keep in mind that aside from toe-in there is nothing to align on a YJ, unless you have adjustable ball joints.
Save some $$ and set the toe yourself, lot's of write ups on it here.
jbolty is offline
post #4 of 6 Old 11-06-2009, 01:00 PM
Louie4
Your drag link is only a tube with threaded ends so you would just need the two tie rod ends (12 & 13). You have the drivers side tie rod end (16) so now you'll need 14 which is the rest of the assembly. Might have been a little cheaper to get the whole assembly (16a). Have you checked your wheel bearing units?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 6 Old 11-06-2009, 03:02 PM
jerseyrider1119
im selling a set from my 95yj due to me upgrading all the joints are fine, pm me for pics
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
I only read the pictures!
95 Rio Grande- 4" Pro Comp lift, 235x75r15 on stock Alloys, Boomerangs, Piolet Trail Lights, Hurc'd, No Sways or Trac, Custom Under Dash Wiring Harness
jerseyrider1119 is offline
post #6 of 6 Old 08-26-2011, 08:00 PM
915kingwrangler
also you have to adjust the drag link, not always but sometimes, although its best not to mess with it, unless your replacing the rods too
*** I AM THE PUNISHMENT OF GOD..IF YOU HAD NOT COMMITTED GREAT SINS, GOD WOULD NOT HAVE SENT A PUNISHMENT LIKE ME UPON YOU..***GENGHIS KHAN
915kingwrangler is offline
where do i find this impossible Brown6041 YJ Wrangler Technical Forum 13 10-15-2009 04:23 PM
impossible gas leak KeepRockin024 YJ Wrangler Technical Forum 6 06-01-2009 10:35 PM
AX-15 Impossible Crack Weelspin TJ Wrangler Technical Forum 3 05-25-2009 12:28 AM
need 1.08 venturis got 1.21 **this **** is impossible** rolledthatho YJ Wrangler Technical Forum 6 04-20-2006 08:22 AM
Snowboard + YJ = Impossible. :-/ Mike611 YJ Wrangler Technical Forum 11 12-26-2003 09:13 AM
