yj air lockers - JeepForum.com
post #1 of 7 Old 08-10-2013, 10:54 AM Thread Starter
bms79
yj air lockers
Needing assistance. I recently purchased a yj that seems to be built right, but thre are some things that I am unfamiliar with(arb air lockers). I understand the basics of differential lockers; they're purpose, how they function, etc. Yesterday pulling out of a gravel road in a hurry when the rear tires broke loose it felt and sounded like there was slippage. The rear locker was NOT engaged. I have only messed with the buttons in my garage. Never locked it in on the trails., but it seems to fuction properly. Any help I could get on the noises would be appreciated. Not even sure if there is a problem.
bms79 is offline
post #2 of 7 Old 08-10-2013, 11:01 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Air lockers are easy. The best way you can test them is by using a set of jackstands or by putting it on a lift. You don't needto have the engine running to lock the differentials. Just jack it up and engage the front or rear locker and spin a tire. If both tires spin the same direction it works. Then disengage. If both spin opposite directions then it disengages correctly. They aren't automatically engaged for comfortable daily driving and saving on tire wear.
Luck Favours The Prepared
Anticanman is offline
post #3 of 7 Old 08-10-2013, 01:45 PM Thread Starter
bms79
thanks for the advice. I have checked them they definately engage. Its pretty much when im horsing aroubd in 2wd, if the rear tires breakloose there is a thumping noise and a vibratin that comes from the rearend. Im afraid to jump on it to hard.. i havent jacked it up to test. I had just flipped the switch in the gravel to see if it engaged. What is the likelihood that it is not disengaging? Thanks
bms79 is offline
post #4 of 7 Old 08-10-2013, 05:32 PM
jeepster93
jeepster93's Avatar
They should be completely invisible when unlocked. No noise, no clicking. In fact no noise when locked coming from the locker either.
Mine, the only noise they make is a light swoosh sound when unlocking and the air line purges. And the solenoids click when locking. The air compressor is the noisiest part. Also, if there is no air pressure, the locker will not lock, no matter the switch(unless broken).
jeepster93 is offline
post #5 of 7 Old 08-11-2013, 08:29 AM
Lemoore-on
Could it be axle wrap causing the vibe & noise?
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #6 of 7 Old 08-11-2013, 11:30 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Probably Axle Wrap
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #7 of 7 Old 08-11-2013, 11:43 AM
Michaelgoesrawr
Yeah. It probably is. It's trying to be resolved in his other thread.
Michaelgoesrawr is offline
4x4 , air lockers , differential , noise
