YJ Advice Needed - Page 3 - JeepForum.com
post #31 of 44 Old 07-31-2013, 09:45 PM
jokerchief462
Yes there is a size limit. You can use Microsoft office 2010. Right click the picture from the menu select open with Microsoft Office 2010 it will display the picture.
Top menu select Picture. From the dropdown select at the bottom Compress Pictures
Right side menu select Compress for Web Pages.
Save to a file and when you go to post on line use the compressed picture and it will post
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #32 of 44 Old 08-01-2013, 08:10 AM Thread Starter
1987Jeep
1987 YJ Wrangler
Here are the pictures
1987Jeep is offline
post #33 of 44 Old 08-01-2013, 08:38 AM
zeus87gn
1987 YJ Wrangler
Looks like a stepper motor
An 85 model truck could have easily been a computer controlled carb
I'm thinking that's not the carb you want
If someone knows how to make it work correctly and can chime in, go for it
I'm Partial to the aftermarket Holley's tho
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #34 of 44 Old 08-01-2013, 06:07 PM Thread Starter
1987Jeep
1987 YJ Wrangler
Does anyone know if I can use this carb? Anyone?
1987Jeep is offline
post #35 of 44 Old 08-03-2013, 06:32 AM Thread Starter
1987Jeep
1987 YJ Wrangler
I'm going to try just leaving that valve unplugged.
1987Jeep is offline
post #36 of 44 Old 08-04-2013, 06:10 AM
fishadventure
In the interest of keeping cost low- I am just curious. Why didn't you just buy the carb from the eBay carb guy that is mentioned in dozens of recent posts here and on other threads? Then you know it works, it's new, and you won't have to buy anything else to fix it or replace it later. Just wondering.
I am a master of doing stuff on the cheap- a friend who is GM-certified, ASE and all that calls me The King Of Cheap. In your circumstance if I couldn't get one from a local scrap yard and rebuild it myself I would have just bought the new carb from eBay???
I digress. I applaud your carb retrofit. Simple and cheap. With more rectangular dollars even I will admit there are better ways, but to just start rolling down the road you are on the path of the least expenditure. It can be argued that it comes with compromises, but carburetors have been working for over 100 years!
fishadventure is offline
post #37 of 44 Old 08-04-2013, 08:31 AM Thread Starter
1987Jeep
1987 YJ Wrangler
Im going to try this carburetor out and hope I can get it to work. If I can't get it to work I will go the same route as many others and purchase it from the EBay guy.
1987Jeep is offline
post #38 of 44 Old 10-09-2013, 02:12 PM Thread Starter
1987Jeep
1987 YJ Wrangler
Ok I was going to purchase the CRT HEI distributor from Ebay and decided to ask the seller if it will work on my 4.0L 242 motor since it wasnt listed as an application for his listing and he said it would not fit.
It only fits the 4.2L
Does anybody know what HEI distributor I can use on this Jeep? Or what are my options?
Thank you.
1987Jeep is offline
post #39 of 44 Old 10-10-2013, 12:20 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Originally Posted by 1987Jeep
Ok I was going to purchase the CRT HEI distributor from Ebay and decided to ask the seller if it will work on my 4.0L 242 motor since it wasnt listed as an application for his listing and he said it would not fit. It only fits the 4.2L Does anybody know what HEI distributor I can use on this Jeep? Or what are my options? Thank you.
To the best of my knowledge all HEI distributers only work on the 258 and none are avaliable for the 242
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #40 of 44 Old 10-10-2013, 07:05 AM Thread Starter
1987Jeep
1987 YJ Wrangler
Any suggestions as what I can do for a distibutor?
1987Jeep is offline
post #41 of 44 Old 10-10-2013, 09:45 AM
Tom95YJ
Tom95YJ's Avatar
Buy a distributer for a 242. And upgrade the ignition coil
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #42 of 44 Old 10-10-2013, 10:24 AM Thread Starter
1987Jeep
1987 YJ Wrangler
I have the stock distributor? What coil do you recommend?
1987Jeep is offline
post #43 of 44 Old 10-10-2013, 10:34 AM
Tom95YJ
Tom95YJ's Avatar
MSD You'll need a harness adapter also.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #44 of 44 Old 10-10-2013, 10:43 AM Thread Starter
1987Jeep
1987 YJ Wrangler
This Jeep doesnt have a harness, computer or an icm. Thats the reason I was wanting to install an hei. Can I do the same with the MSD?
1987Jeep is offline
4.2 to 4.0 swap , project jeep
