YJ Advice Needed - Page 2 - JeepForum.com
post #16 of 44 Old 07-10-2013, 03:16 PM
rambo3489
Well I see a long stressful road ahead no matter how you look at it. What is your background with Jeeps and such? I will tell you you WILL likely spend more than $1000 to get it running. BUT thats not a bad thing in my mind.
See to me I bought my YJ knowing I had work to do on it. I knew that. I actually wanted that. Again I don't know what you want out of it. BUT if you are up to it I would do want was stated before. Buy a 4.2 intake, get a cheap header off of ebay, figure out how to wire and fire it up (this will be by far the most challenging part), work out any other kinks you found.
If you are able to accomplish all of that you will be in a whole other class. You will know your Jeep more intimately than you ever thought possible. You will have the knowledge to fix anything on it without fear. Diagnose problems on the fly and come up with simple remedies to get you home. It is pretty cool to be able to do. I say go for it. There's plenty of info on the internet about it. If you have questions ask us. The guys around here are pretty good ****. And we've been there before. No matter where that is. Good luck.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #17 of 44 Old 07-10-2013, 03:17 PM
rambo3489
Google it. It's a MC2100, or better yet MC2150. They are Ford carbs and they were put on almost any Ford vehicle form the 60's through the 80's. You will want one with a 1.08 venturi.
<a href="
THE YJ MY WAY</a>
post #18 of 44 Old 07-10-2013, 04:12 PM Thread Starter
1987Jeep
1987 YJ Wrangler
I have no experience with Jeeps what so ever. All my life I have messed around with Fords. I will for sure look at all the details to make sure I know what i need as I go. I appreciate all the input and I am sure I will be asking for help in the near future. Rambo3489 I may take you up on that spacer will get back to you when I find a carb.
1987Jeep is offline
post #19 of 44 Old 07-10-2013, 05:44 PM
superj
You might want to see if it has a stroker in it. That's the only reason to put a 4.0 block with a 4.2 head. Mine is the same way
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #20 of 44 Old 07-10-2013, 05:45 PM
superj
And the motorcraft came on ford tricks and cars in the 70s and early 80s
superj is offline
post #21 of 44 Old 07-12-2013, 09:54 AM Thread Starter
1987Jeep
1987 YJ Wrangler
How can you tell if it has a stroker in it?
1987Jeep is offline
post #22 of 44 Old 07-12-2013, 10:34 AM
zeus87gn
1987 YJ Wrangler
This was my thought as I was reading thru the thread
Old school carb style stroker
With the 4.2 head, a 4.0l header won't work - you'll need a 4.2 header
The difference is in the port size and shape
The 4.2 has rectangular ports, the 4.0 has "D" ports
The 4.0 header suited for the D ports will cause problems on the rectangular 4.2 ports
Handicapped license plates are not for mentally handicapped people -
"Man has not yet evolved an inch from the primordial slime that spawned him." Mark Blankfield, Jekyll & Hyde... Together again
zeus87gn is offline
post #23 of 44 Old 07-14-2013, 11:43 AM Thread Starter
1987Jeep
1987 YJ Wrangler
ok I purchased a used intake and exhaust manifold. Should I remove this egr tube that connects both manifolds together and plug them? Do I need this heater that is bolted under the intake manifold?
1987Jeep is offline
post #24 of 44 Old 07-14-2013, 12:21 PM
roadyrob
1987 YJ Wrangler
I run a offenhauser manifold that doesn't have the egr or heater and it runs good, so no, you don't need them
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #25 of 44 Old 07-14-2013, 12:27 PM Thread Starter
1987Jeep
1987 YJ Wrangler
ok great I will remove the tube and plug the holes. I will also remove the egr valve. Now I have to look for a carb. Thanks roadyrob!
1987Jeep is offline
post #26 of 44 Old 07-31-2013, 07:48 PM Thread Starter
1987Jeep
1987 YJ Wrangler
ok I bought a MC2150 but I think its wrong because it has a valve or something that looks like a stepper motor with a plug for two wires. Does any one know what this is? The tag on the carb says E5TE YA the ad on Ebay said it came off of a Jeep that's why I bought it. Any help is appreciated.
Thank you.
1987Jeep is offline
post #27 of 44 Old 07-31-2013, 08:06 PM
superj
googled the part number you listed
here is the return:
This carburetor was made by Ford , . It is a F2-2150 . This carburetor has a part number of E5TE-YA and used on 85 Ford trk
superj is offline
post #28 of 44 Old 07-31-2013, 08:17 PM Thread Starter
1987Jeep
1987 YJ Wrangler
Does that mean that I can't use it?
1987Jeep is offline
post #29 of 44 Old 07-31-2013, 08:26 PM
superj
Take a pic and let us see the electronic deal. That might be the dealio that kicks the idea up when you turn on the ac
superj is offline
post #30 of 44 Old 07-31-2013, 08:38 PM Thread Starter
1987Jeep
1987 YJ Wrangler
I tried posting a picture it says it exceeds the size?
1987Jeep is offline
4.2 to 4.0 swap , project jeep
