YJ (88) Gauge Wiring Diagram - JeepForum.com
post #1 of 4 Old 05-07-2007, 10:50 AM Thread Starter
fh2level
I know there are several threads like this but I have not found one to match my search. I need to replace all of my gauges in my dash and as you probably know the YJ's have a flex circuit board. Does anyone have a wirind diagram for the gauges?
Thanks for any help.
fh2level is offline
post #2 of 4 Old 05-07-2007, 10:57 AM
kloppk
Ignore the circled area...
kloppk is offline
post #3 of 4 Old 05-07-2007, 03:55 PM
bharris68
Daily Driver
Question: Why do you need to replace all the guages in your dash? I find that all of mine still work like champs in my '89 after 180K or so....
bharris68 is offline
post #4 of 4 Old 05-07-2007, 05:09 PM Thread Starter
fh2level
None of them work, one needle is bent, I belive it is the voltmeter, Don't know how...and the plastic is cracked. I already replaced the Tempurature gauge so I am going to finish up with the rest and get the Autometer YJ Dash Pod from 4wd.
Thanks for the diagram kloppk.
fh2level is offline
Gauge Cluster wiring diagram! wrestler22491 YJ Wrangler Technical Forum 16 11-25-2013 09:47 PM
Wiring Diagram jarrodg TJ Wrangler Technical Forum 3 01-07-2008 07:41 PM
Wiring Diagram RFrazer JK Wrangler Technical Forum 9 06-25-2007 11:04 AM
'87 YJ Wiring diagram wwest76 YJ Wrangler Technical Forum 1 01-21-2007 04:16 PM
Need sending unit to gauge wiring diagram for 88YJ b1web YJ Wrangler Technical Forum 1 03-30-2004 06:09 PM
