YJ 5.2/5.9 swap questions - JeepForum.com
post #1 of 68 Old 08-17-2011, 03:03 PM Thread Starter
drhill
Hi Everyone...I've been searching jeepforums for a long time and finally have enough info to post a question! I'm looking to purchase a 94-95 YJ 4.0 5 speed and swap in a same year 5.2 or 5.9 V8 as simply as possible. I'm in California and want to make this Jeep California BAR legal. I also want to keep the AX-15 and everything else as close to stock as possible.
Here's my plan:
5.2/5.9 complete engine with all accessories, wiring harnesses, computer and exhaust
3.9 Dakota bellhousing, flywheel and splash sheild
Use stock AX-15 clutch, pilot bearing and slave cylinder
Advanced Adapters V8 swap motor mounts
Inexpensive swap radiator? (Heard you can use a SBC swap radiator?)
5.2/5.9 fan clutch should work in stock 4.0 fan shroud?
Modify V8 y pipe to fit Jeep
Wiring - work through Dodge and Jeep wiring diagrams - splice as necessary.
I am hoping that with this setup I will not have to move or work on anything from the transmission back through the driveline and that all factory V8 emission systems will work properly. Also all Jeep gauges, check engine light and diagnostic port will function as well.
Any tips or tricks? Anything I'm forgetting? For example, do I need to source a computer from a V8 truck with a manual trans? Or will one from an auto trans work fine?
Thanks for the help!!
drhill is offline
post #2 of 68 Old 08-18-2011, 09:27 AM
bmgadg
The computer will have to come from a manual dodge truck. If you're going 5.9, then use the 5.9 clutch and flywheel. I fits fine and provides more clutch area. The stock exhaust manifolds did not work, I went with center dump block hugger headers from summit for around $130. Yes you can use a sbc radiator as the in and outputs are in the correct location. I got the bolt in conversion radiator from oconee offroad on the cheap. As for as emissions compliance, I have no idea since I live in a state that doesn't require any testing. I would assume you'll need a new catalytic converter at a minimum. Run 3" pipe from the y-collector off the headers all the way back to a flowmaster with turndowns and it will sound awesome.
bmgadg is offline
post #3 of 68 Old 08-18-2011, 09:32 AM
KingtheZJ
go with the 5.9. more power fro the same work. and with regard to the exhaust manifold, i have a set off a ZJ, but i assume the clearance issue you run into is the firewall, not the inner fenders like we do. the ZJ can only use ZJ specific headers. all the dodge ones have clearance problems with the inner fender.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #4 of 68 Old 08-18-2011, 09:49 AM
bmgadg
Yes the problem is clearance with the firewall. Center dump headers work perfectly.
bmgadg is offline
post #5 of 68 Old 08-18-2011, 12:10 PM Thread Starter
drhill
That all sounds ok....the trick with california is I have to use whatever is stock for the truck I am transplanting the engine from or the smog legal replacement headers for that truck.
Wonder if I got the motor from a ZJ if those manifolds would work on the YJ? Anyone know? I cant use the block huggers for sure unfortunately
drhill is offline
post #6 of 68 Old 08-18-2011, 01:19 PM
bmgadg
Hmmm I have no idea, but I do know the dodge ram manifolds I had hit the firewall.
bmgadg is offline
post #7 of 68 Old 08-18-2011, 01:24 PM
sbsg2005
some early dodges had center dump manifolds I wonder of they would work on magnum heads.
sbsg2005 is offline
post #8 of 68 Old 08-18-2011, 01:45 PM
bmgadg
I'm pretty sure they would fit, here's a link to the application for the headers I used on summit's website http://www.summitracing.com/parts/SU...n/?prefilter=1
bmgadg is offline
post #9 of 68 Old 08-18-2011, 02:55 PM Thread Starter
drhill
I just found this article from JP Magazine online about swapping a 5.2 into a TJ...they used the manifolds on the engine in this photo...
http://image.jpmagazine.com/f/956802...5_vtj_03_z.jpg
would these work in a yj?
drhill is offline
post #10 of 68 Old 08-22-2011, 12:12 PM Thread Starter
drhill
anyone?
drhill is offline
post #11 of 68 Old 08-22-2011, 12:42 PM
bmgadg
That looks just like the stock manifolds that were on my engine. They could possibly work, but they just come too close to the firewall in my opinion. Are you avoiding headers for emissions reasons?
bmgadg is offline
post #12 of 68 Old 08-22-2011, 03:10 PM
sbsg2005
You could try some of these from an early 80's dodge d/w150. They are center dump and exit fairly close to the block. And being that they are a stock cast manifold they would most likely never notice during an inspection. And they will fit a magnum head I just tried the on the 5.2 I have on the stand.
sbsg2005 is offline
post #13 of 68 Old 08-22-2011, 07:29 PM
Noltz
YJ Wrangler
Remember your donor engine must come from same or newer vehicle for Cali smog. At least I've read that several times. 94-95 YJ means you must use 94-95 engine, and '96+ is OBD2, more wiring & doubt you'll get the OEM YJ dash to work with it.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #14 of 68 Old 08-22-2011, 11:13 PM
Fin_Reaper
Noltz - didn't you once say that a 5.2 wouldn't fit in a YJ? Now you're doubting the OEM dash will work?
If he's got an OEM 94-95 speedo/tach, the gauges will work.
I'm running a 96 OBD2 5.2 in my '88 YJ. Using my OEM '88 YJ fuel level gauge, oil pressure gauge, water temp gauge and a 94-95 tach/speedo. Sure a little wiring, but it all works perfectly.
Don't be afraid of OBD2, just have patience or moolah to pay someone like Evan at BWO. The scan capabilities can be very helpful.
Although I don't have any experience with the AA motor mounts - I can vouch for the Novak setup. Very simple and flexible - even after install.
For the clutch, I found the 88 YJ master, 95 YJ slave and 5.2 pressure plate/clutch work just fine.
Radiator - I took my 88 YJ radiator to a local rad shop. They rodded the fins and swapped/enlarged the inlet and outlet ports for less than $150.
Exhaust - I did just like bmgadg suggested and it is too loud for me. I will be working fast to reduce the noise. Driving the jeep with ear plugs sucks... I do like the summit block hugger headers, but I expected more out of the ceramic coating to cut down on heat. I'll have a 3" flowmaster 40 for sale soon if you're interested.
I just got my first 15+ mpg tank, up from 10 with the 4.2.
88 YJ with stuff
Fin_Reaper is offline
post #15 of 68 Old 08-24-2011, 05:45 PM Thread Starter
drhill
Great info guys..thanks for the input. I bet I can squeak by with those center dump manifolds if need be. Can't imagine anyone would notice unless the stock 94-95 5.2/5.9 manifolds have emissions fittings in them. I would try to stick w/ OBD I as it's just easier...OBD II has better diagnostics etc...
I may still try to upgrade the radiator somehow as I live in the desert and it is 118 degrees here today...like my a/c and I hate overheating!
drhill is offline
4.0 Swap Questions Snipeston YJ Wrangler Technical Forum 11 09-04-2013 02:21 AM
Questions about 4.3 swap? upnorthbacon YJ Wrangler Technical Forum 15 09-22-2010 03:29 PM
body swap VS motor swap questions baltimorebiker YJ Wrangler Technical Forum 9 03-29-2010 09:49 PM
The 4.2L to 4.0 Swap questions? sports100 YJ Wrangler Technical Forum 2 08-09-2009 09:54 AM
2.5L to 4.0L swap questions ZJ1209 TJ Wrangler Technical Forum 13 04-23-2009 09:34 PM
