YJ 5.0 overheating ,need help - JeepForum.com
post #1 of 21 Old 09-24-2006, 08:40 PM Thread Starter
Jets22
Hoping for some help from some members who may have this same problem. I have a YJ with 5.0 EFI roller motor conversion. Pulled from a late model non MAS. I am running an aluminium Griffin radiator custom Aluminium shroud, (ran it with and without and over heated with and without shroud) very good high efficient electric fan. This is wired with thermo controller and a bypass on off switch. I was running a 180 Thermostat. HAve lowered to 160 and still over heats on highway. Has a Mile Marker winch up front (only thing blocking the grill area) Truck runs fantastic around town with no problems even in the heat of summer and traffic. Motor runs flawless idle all the way up . PROBLEM: When I run at highway speeds it overheats. Fan on, fan off I've tried everything..Get it off the highway and it will cool back down. It is only tacking out at 2400 or 2500 rpm in 4th (has a T18 and 4:10 running 38 SSR'S) It's not running lean, plugs all look good.
I'm going nuts on this one guys...Any other 5.0 swaps have this problem? Or anyone had similar issue. Any help on this one would be VERY appreciated.
Jets22 is offline
post #2 of 21 Old 09-24-2006, 08:55 PM
5.0YJ
i thought i was the only guy with a 5.0 swap in a YJ....mine is the same setup as you almost...except i run a stock rad with a clutch fan...i bought it with the swap done like this..never overheated unless i was beating it hard on the trails...then the rad got clogged with mud and the fins were beat up pretty badly that you could see right thru the rad....i got a stock replacement and plan to do a efan on it also....maybe try bleeding the air out of the system somehow...post up some pics of your setup
5.0YJ is offline
post #3 of 21 Old 09-24-2006, 09:00 PM Thread Starter
Jets22
I'll post some pics tomorrow. it really is strange. I do not believe it is air pocket at this point. The winch shouldn't effect it. (I had same winch on my CJ and no overheating issues) This one is running the 5.0 but I'm at a loss on the highway problem.
Jets22 is offline
post #4 of 21 Old 09-24-2006, 09:12 PM
Bob_R
I run the same radiator, different motor but same rad. It sounds like you have air in there. At high speeds it will overhead with air trapped inside. It gets trapped in the block. This sounds stupid but I had to put my jeep on a ramp to rid the air enough. I had no way to force the water through.
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL TREAD LIGHTLY
Bob_R is offline
post #5 of 21 Old 09-24-2006, 11:43 PM
bombadillo
try putting a fan clutch in it, as well as a couple bottles of water wetter. Its supposed to drop your coolant by as much as 20* or so.
93 white wrangler, warn rock crawler bumper w/guard, custom rear bumper, warn lights, superlift 3.5" suspension lift, Lift shackles rear, (Soon to be front too) crappy shocks, 32x11.50 BFG MT's on eagle alloy 10 hole wheels, Swaybars and track bars removed. H4 conversion headlights, Hi-Lift ghetto mounted, Header from above ^^ and other goodies.
bombadillo is offline
post #6 of 21 Old 09-25-2006, 07:40 AM
dankeenan
Your electric fan may be impeding air flow at highway speeds. I know this sounds weird, but in some cases the air coming in is at a higher speed than the fan will allow, thus the fan ends up being a restriction. You might want to runs a different fan configuration to see if that is a problem.
Dan
dankeenan is offline
post #7 of 21 Old 09-25-2006, 05:51 PM Thread Starter
Jets22
I ran the set-up with different fan and no shroud and same problem, 180 160 thermostats and it does have additive now added to try and lower the temp even more. Same situation hot day highway she overheats. Pull off and run at around town speeds she cools back down. replaced the fan with the biggest you can run and a custom made aluminium low profile shroud and same results. Tried running at highway speeds and turned the fan off so it is free spinning ...same results. This thing is killing me guys.
Jets22 is offline
post #8 of 21 Old 09-25-2006, 07:44 PM
bigbluejp
I'm looking to swap in 5.o any info would be great
bigbluejp is offline
post #9 of 21 Old 09-25-2006, 08:41 PM
SOA-87-YJ
1987 YJ Wrangler
What rpm are you running at on the highway? Might want to try a Edelbrock Victor Water Pump it should lower your temp by 15 Deg. I think it is water flow not air flow. When you run around town your keeping the rpms up and going down the highway therenot as high.
BUILT ON A BUDGET...NOT A TRUST FUND!!!!!Founder of Pocono S-10 and North East Pa Offroad Club.
1987 YJ
SOA Lift, Rancho 2"Add a Leaf,MFI 4.0L Bored & Cammed, 5 Speed, Procomp Shocks, 8.8 w/ E Locker, 4.88, AA SYE, Custom F & R Bumpers w/ Tire Swing, Custom CV Shaft, JKS Disconnects, 15x8 Black Steelies,Procomp Xtreme MT 35x12.50x15, JB4X4 HighSteer, Posion Spyder Trail Cage, MileMarker E8000 winch., AtoZ Sliders, HighLift & Hood Mount.
SOA-87-YJ is offline
post #10 of 21 Old 09-25-2006, 09:00 PM
mobility
Have you run it without the winch in place (with that motor)? Depending on the size and profile of the winch and fairlead it could start to buffet the air at higher speeds and direct it up over the hood and reduce what's pasting through the grill.
Reduce the airflow and a bigger motor....maybe
mobility is offline
post #11 of 21 Old 09-27-2006, 06:25 PM Thread Starter
Jets22
Did the high flow when I dropped the 302 rollere EFI in. With the overflow tank I would have to assume if it had an air pocket it would dissapate? Don't really know on that. I know others run this same set-up and say no overheat issues so I'm thinking something is strange. You would think around town it would overheat..not running down the highway
Jets22 is offline
post #12 of 21 Old 09-27-2006, 07:29 PM
littleman66
littleman66's Avatar
http://www.pirate4x4.com/forum/showt...highlight=TOTW
littleman66 is offline
post #13 of 21 Old 09-27-2006, 07:38 PM
5.0YJ
i would try removing the winch and see if that helps any...
5.0YJ is offline
post #14 of 21 Old 09-27-2006, 10:12 PM
DaemonJeep
I got a 302-t18 setup with a winch up front and an electric pusher fan in front of a 3 core stock style radiator and no problems. Do you hear any pinging or faint knocking? I'd sure check that timing. Mine is at 6 degrees btdc base timing with a carb. Also can't remember but do some smallblock fords depending on year have reversed water pumps like some chevy small blocks? Any Ford guys out there? Chime in if that may be the case.
Hey who cares what I got, it goes through mud, that's all that matters!!
DaemonJeep is offline
post #15 of 21 Old 09-29-2006, 04:57 PM Thread Starter
Jets22
I can't imagine it's the winch, ton's of people run this set-up with no problems..it's taching out at 2400 down the highway
Jets22 is offline
overheating? attackcammel TJ Wrangler Technical Forum 7 07-04-2010 12:58 PM
overheating? Mudzilla6661 Wrangler General Discussion 8 08-15-2009 09:33 PM
overheating 87 danthman YJ Wrangler Technical Forum 6 03-05-2009 07:44 AM
overheating, only at 55+mph ...? TXjeepTJ TJ Wrangler Technical Forum 7 09-19-2007 08:55 AM
Overheating Kel Dub TJ Wrangler Technical Forum 7 01-21-2006 03:25 PM
