Yj 4x4 problem - JeepForum.com
post #1 of 1 Old 01-05-2012, 12:53 PM Thread Starter
Raven4424
Yj 4x4 problem
I'm having issues with the 4 wheel drive. The previous owner has removed the vacuum system and installed a posi lock system on the front. Here's the problem when put in 4 wheel and you start to drive the jeep pulls to the pass side hard as the wheel is not locking in. So I jacked up the pass side of the jeep and took off posi system and slid collar over to see what was going on. With 4 wheel locked in and collar slid over to engage it I can spin tire forward a couple times and then it will lock and I can't turn it. But if I rock the wheel backwards it comes unlocked and I can free spin the wheel again couple times and it locks. So what you think is stoping it from engaging?
Raven4424 is offline
4 wheel drive , 4x4
clutch problem ? Master / Slave Cylinder Problem rthompson48082 YJ Wrangler Technical Forum 34 11-30-2011 06:31 PM
Belt problem, blinker problem, and a random problem... Mike89db TJ Wrangler Technical Forum 10 12-14-2009 06:34 AM
brake pad problem, and front drive shaft problem bluejeep2088 TJ Wrangler Technical Forum 1 05-12-2008 10:34 AM
Brake Fluid problem or Jeep Drinking problem daledaniel TJ Wrangler Technical Forum 6 01-04-2008 10:11 PM
FINALLY! fixed idle problem and stalling problem Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-28-2006 08:50 PM
