YJ /4L ECM on Cherokee Harness - JeepForum.com
post #1 of 1 Old 03-20-2012, 10:04 PM Thread Starter
ecinge
Asking for some advise. I am swapping a cherokee 1996 HO 4.0L engine in my 1990 Wrangler YJ. The engine will be stroked to 4.6L as per "4.6L Poor man's stroker" receipt.
Question # 1: I bought a 1994 Wrangler 4.0L / (Manual Trans) computer (ECM). I realized after "winning" the bid on ebay that I forgot to check the plugs of Cherokee 1996 vs Wrangler 1994. The guy or "seller" tells me that the ECM will plug in the Cherokee Harness. It is correct? or no.
Question # 2: My actual engine (1990 258-4.2L) will be the donor for the stroker parts. I am interested to use all the front stuff (i.e P/S Pump, Alternator, A/C compressor etc) in the 4.0L block. I want to run the mechanical fan. It is possible?
ecinge is offline
cherokee , ecm , wiriing harness
cherokee wiring harness same as wrangler? ska-doorider TJ Wrangler Technical Forum 2 03-08-2012 11:01 AM
87 yj under dash harness with 94 engine harness LikeeABosss YJ Wrangler Technical Forum 2 10-22-2010 02:10 PM
Engine harness question from 98 Cherokee Sector65 YJ Wrangler Technical Forum 0 08-12-2009 04:31 PM
Seats/Harness bar for 5 point harness Metzgerhund TJ Wrangler Technical Forum 18 04-04-2008 10:24 AM
Help me out... I need an IPF Harness IMAAaron TJ Wrangler Technical Forum 1 01-23-2004 12:46 PM
