YJ 4cy Engine Question - JeepForum.com
post #1 of 6 Old 06-06-2013, 12:44 PM Thread Starter
jdg
Just got a 95 wrangler the other day, drove fine. After I drove it about a day I noticed it would sputter some times like it was about to die then surge back The other day I was driving and it kept dying on me but would start right back up. Any idea what could be causing this? I was thinking of replacing the fuel filter and fuel pump to see if that did the trick.
jdg is offline
post #2 of 6 Old 06-06-2013, 01:20 PM
Siva283
Fuel filter is good to replace since you dont know when it was last. I wouldnt jump to the fuel pump yet. This sounds like a CPS going out on you. There is a test procedure if I remember correctly but I dont remember it. I am sure Que will be along shortly. Listen to him trust me on this you will save alot of money and headaches and potentially learn ALOT.
Ask me how I know...
Siva283 is offline
post #3 of 6 Old 06-06-2013, 02:13 PM
jsd1991yj
I would also inspect your ignition system (plugs, wires, cap, rotor, coil) and make sure they all look good. And maybe run some injector cleaner to make sure they are spraying correctly.
jsd1991yj is offline
post #4 of 6 Old 06-06-2013, 07:29 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
You should check to see if you have any engine codes. There's a "how to" in the FAQ's section.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #5 of 6 Old 06-17-2013, 11:15 AM Thread Starter
jdg
replaced fuel filter no go, will be buying a crank sensor today to see if that works from what i have read it could be the issue
jdg is offline
post #6 of 6 Old 06-17-2013, 12:01 PM
idaholtby
I strongly suggest troubleshooting this issue before throwing parts at the rig. Have you at least checked for codes as previously mentioned? If no codes, then test fuel pressure at the fuel rail. You can rent testers at most auto part stores. Check your fuel pressure while idling, then remove the vac line on the fuel pressure regulator and note the pressure change. Then shut it down and watch how quickly pressure bleeds of if at all. The problem with replacing parts willy-nilly is that there is a strong potential of installing a bad part in place of an otherwise good one. This costs more money and further complicates the actual fix.
idaholtby is offline
