YJ 4'' suspension lift: RE or skyjacker? - JeepForum.com
post #1 of 19 Old 11-19-2005, 09:52 AM Thread Starter
YJtank
Could you sort this out? I am about to change my OME 2.5'' kit with a 4'' kit. I am extremely happy with the ride comfort of the OME kit but I need to go higher (plus the OME kit is 5 years old). I need to get a 4'' kit that has the same ride comfort as the OME. From what I know RE and skyjacker have such reputation. Which one to go for? Any other brands, maybe? I'd rather spend something more than compromise my ride quality.
YJtank is offline
post #2 of 19 Old 11-19-2005, 10:00 AM
Silver yj
I have the 4" skyjacker " easy ride " they say it gives you the stock ride but are able to off road with it, the kit has been on my jeep for 4 years and I have had it more off road then on and it seems fine, I have never driven a jeep with a kit from the compoany you have so I can't compare the ride for you but the Skyjacker has been good for me and the ride isint to bad BUT it is a JEEP so im not sure what kind of ride you will get as far as comfort.
Silver yj is offline
post #3 of 19 Old 11-19-2005, 10:02 AM
Josephrk24
SKYJACKER....... better
1990 YJ I6 258 AX-15 NP 231 *Now with Posi-Lok*
5 Inch BDS Lift
33X13.50 Mickey Thompson BaJa Claws
Early YJ club member #29
Josephrk24 is offline
post #4 of 19 Old 11-19-2005, 10:34 AM Thread Starter
YJtank
OME stands for Old Man Emu. The ride quality is miles away from stock (really!). I know its a jeep and it shouldn't ride like a cadillac. I heard skyjacker softride 4'' springs are good but most others say RE 4'' standard or 4.5'' extreme duty kit are a lot softer, more stable and with better flex. Someothers say BDS. What gives? You see where my dilemma comes in?
YJtank is offline
post #5 of 19 Old 11-19-2005, 11:00 AM
jipjip
jipjip's Avatar
i have been doing a lot of research into this topic also as i want to do a 4" setup on my yj. i have come to the conclusion that the best 2 to go w/ are RE or BDS, now depending on if you have a hard top,winch,e.t.c.. depends on which kit to go w/. the RE standard lift if for soft top and little stuff. the RE XD kit if for all the heavy stuff. as w/ BDS it is all the same kit. just for the heavier setup, they put front leaf spring packs in the rear also and this works just fine. personally i have made the decision to go w/ BDS for the fact that they have a no questions asked warrenty policy, if the spring breaks, sags, bends, e.t.c... they replace it for free, no questions asked. this could be a very good thing for the extra off roader croud that are worried about breaking and bending leaf packs all the time. plus the BDS kit is a LOT cheaper that the RE kit.
your choice...
jipjip is offline
post #6 of 19 Old 11-19-2005, 11:18 AM Thread Starter
YJtank
4'' standard RE on heavy load yj and 1'' BL?
does that mean that Skyjacker is out of the way? Indeed have a hardtop, winch and rectangular nerf bars. Wouldn't this extra load make the RE 4'' standard even softer? That's better for me. Plus I also have a 1'' body lift that I was planning on keeping, so that would compensate for the drop due to the extra load. I would say then 4'' standard RE? I thinking we are closing to a solution here?
YJtank is offline
post #7 of 19 Old 11-19-2005, 11:25 AM
jipjip
jipjip's Avatar
i'm sure the standard kit would be fine for the road. but any serious off roading and you might be bending leaf packs w/ all that weight. if you enjoy a lot of wheeling, i would advise the RE HD kit and be done w/ it. the spring packs in this kit are progressive rate, so on the road it will be just as comfortable, but can handle the excessive rigors of the off road. amazing flex too
jipjip is offline
post #8 of 19 Old 11-19-2005, 05:39 PM
jeep63
jeep63's Avatar
I run the RE Extreme Duty 4.5" and I have nothing but good to say about the lift. The ride on road is good. Come on, you are lifting your jeep so you have to expect some change in on road comfort.
Doug
'89 YJ fully loaded.
jeep63 is offline
post #9 of 19 Old 11-19-2005, 06:42 PM
leurinimj
Good to go
I put a sky jacker 4" in my 87 yj. Good ride. but its very important to not torque your shackle and spring purch bolt until you have the weight of the vehicle on it. My buddy did his the oposite because he wanted and extra 1/2" higher. crappy ride. very stiff. So follow the instructions and you will like it.
MIKE
leurinimj is offline
post #10 of 19 Old 11-20-2005, 07:53 AM
ghiradelli777
what is the BDS system??? i have seen the letters but i didnt know wat they stood for....i need a lift too and i am just tagging along w/ this forum post...
1992 YJ Sport White 4.3 swap in progress
Eagle Scout Jeep Owner
ghiradelli777 is offline
post #11 of 19 Old 11-20-2005, 10:19 AM
Sugarfuzz
Black Diamond Suspension
2000 Jeep Wrangler 4.0 | 4" Superlift, 33x12.50 BFG Mud Terrains, 4WDHW Rear Bumper
OTHER RIDES:
1993 Mazda RX7(HBP, T04R), 1999 Honda Civic Si(AutoX/DD Car), 1975 & 1977 Honda GL1000
Sugarfuzz is offline
post #12 of 19 Old 11-20-2005, 11:36 AM
RAYMAN975
no its not black diamond. BDS is Big Dick Suspensions, seriously but i heard BDS and blackdiamond are both pretty good
RAYMAN975 is offline
post #13 of 19 Old 11-20-2005, 12:14 PM
blevinsbulldog
RE ---- Hands Down !!!!!!!!!!!!!!!!!
95' RIO GRANDE
2.5 AKA THE SCREAMING HAMSTER
REAR TRACK BAR REMOVED
1 1/4 SHACKLES---3''BL
33X12.50 BFG A/T
GREEN JEEP CLUB MEMBER # 176
blevinsbulldog is offline
post #14 of 19 Old 11-20-2005, 05:52 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
The RE XD kit uses better springs (multi rate) and has upgraded hardware. Just so you know the RE kits are measured/designed for 6cyl, winch, HD bumpers, tire cariers, hardtop, body armor, skid plates and all of the stuff you normaly take on a trail ride (@150lbs+ 2 people) to get their lift height. 99% of the other mfgr, use a 4banger, soft top, no mods and 1 person for their "lift height". I have the RE XD 2.5 in lift and with half of my normal trail load (DD tool load) I still have nearly 3.5 in of lift. Fully kitted out, it settles out at 2.75 in. Empty or loaded, the RE HD kits ride better than 90% of the other lift kits out there.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #15 of 19 Old 11-20-2005, 07:51 PM
LTB
I put the R.E. 4.5 xd in and I think the ride is great , on and off road
92 yj a continuous work in progress
K&n fipk,d44 locked w/4.11 rear d30 4.10 locked front, rubicon express 4.5 xd lift, rubicon express c/v driveline, advance adapters sye,posi lock, 33 12.5 trailcutter tires,besttop 6'' flares 4.0 w/5sp ,milemarker 10,500 hydrolic winch
LTB is offline
skyjacker 2.5 inch suspension lift vanner77 JK Wrangler Technical Forum 8 06-09-2009 11:28 AM
2" Skyjacker suspension lift on a yj ddrongowski YJ Wrangler Technical Forum 2 03-11-2009 02:56 PM
Skyjacker 2.5" JK 4-Door Suspension Lift wayoflife JK Wrangler Technical Forum 4 09-04-2006 11:07 PM
skyjacker 4 inch rock ready suspension lift idcx3 TJ Wrangler Technical Forum 1 02-03-2003 09:13 PM
is an 8 inch skyjacker suspension lift too high? 8inchwrangler95 YJ Wrangler Technical Forum 1 10-27-2002 03:37 PM
