YJ 4.2, 1987 Trouble with sensors of the intake - JeepForum.com
post #1 of 5 Old 08-11-2013, 06:32 AM Thread Starter
Smejky
Hello guys, I have buy the old veteran Wrangler YJ 4.2 (year 1987) and now I have the trouble with the sonsors in the engine. Please do you know, which the sensors are on the photo (below)? These sensors were not connect, so I don't know the function of the sensors. There are also a lot of wires (different colours :-)) - please do you somebody have some electric schema of the connection? And do you know also the colour of the wire which is to the electric choke of the carburetor Weber 32/36 DGEV.
Thank you very much for your advices
Kind regards Smejky
Smejky is offline
post #2 of 5 Old 08-11-2013, 06:40 AM
Old4X
1990 CJ7
If you have replaced the OEM carb with a Weber, those sensors are useless now, just ignore them.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 5 Old 08-11-2013, 06:46 AM
Old4X
1990 CJ7
http://home.sprynet.com/~dale02/list.htm
Your YJ is set up just like the late model CJ in this link. You should be able to find what you want here.
Old4X is offline
post #4 of 5 Old 08-12-2013, 04:52 AM
jay-h
#3 is the sensor for the temperature gage (at least on mine)
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #5 of 5 Old 08-12-2013, 09:50 AM
dancytron
First, check if this was done (the wiring part) http://www.jeepforum.com/forum/f8/ho...bypass-522262/
If not, do it. This will bypass the computer and make the sensors irrelevant.
When you say "choke on all the time" do you really mean even with the engine off. No, it won't work like that. Stock, it was triggered by an oil pressure sensor so it was only on when the engine was actually running. You could change over to a manual choke or you could set it up with a relay triggered to only supply power when the key is on.
dancytron is offline
