yj 350 swap aftermarket speedometer - JeepForum.com
post #1 of 7 Old 03-10-2014, 08:32 PM Thread Starter
mason_128
I have a 94 yj and im in the middle of a 350 swap. All I have left is to wire up the gauges. I'm going with aftermarket auto meter. Does anyone know how to wire up the speedometer? There's 3 wires going to the sending unit. Orange‚ white & orange and blue & black. They all run to the ECM plug‚ I'm not using the ecm. And the orange & white wire also runs to the gauge cluster plug. Does anyone know how to make it work?
mason_128 is offline
post #2 of 7 Old 03-12-2014, 11:05 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
What kind of VSS do you have electronic or mechanical? Are you running efi that will need a VSS input? If you have a electronic VSS do you know the Pulse Per Revolution?
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #3 of 7 Old 03-12-2014, 04:17 PM
Why J?
Why J?'s Avatar
From the VSS:
Orange is 8v supply from the ECU.
Black w/ blue strip is ground.
Orange w/ white stripe is signal wire back to ECU and the speedo.
You can wire the orange w/ stripe directly to the speedo and 12v from a switched power source to the orange and the speedo will work correctly.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #4 of 7 Old 03-13-2014, 09:26 PM Thread Starter
mason_128
Thanks a lot for the help.
post #5 of 7 Old 03-14-2014, 09:44 AM
AbAngler
I'm going to save you a whole lot of time and frustration. Seriously take a look at the newer GPS speedos. If you have already purchased an electronic Autometer speedo, there is a new GPS module that just hooks up to the guage. http://www.autometer.com/cat_accesso...l.aspx?vid=234
Took me about 10 minutes to install mine and I'm not a fan of anything electrical.
Might cost a bit more, but its the easy button.
My build in progress
http://www.jeepforum.com/forum/f22/89-yj-4-3l-bunch-other-stuff-build-1171991/
AbAngler is offline
post #6 of 7 Old 03-15-2014, 07:32 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
That is pretty cool. Because I had a 40 tooth tone ring and my ECM wanted to see a 4PPR I had to buy a Dakota sgi-5. Then I set the autometer gauge to 4000PPM (ECM output to gauge).
March 2017 YJOTM
87TPIYJ is offline
post #7 of 7 Old 03-18-2014, 03:01 PM
AbAngler
Thats basically what I was facing too. This seemed like a no-brainer. They are apparently getting quite popular with the muscle car crowd as well. When I bought mine, they had sold 4 others that morning. Good product.
AbAngler is offline
