-   -   yj 350 swap aftermarket speedometer (http://www.jeepforum.com/forum/f12/yj-350-swap-aftermarket-speedometer-2202353/)
mason_128 03-10-2014 08:32 PM
I have a 94 yj and im in the middle of a 350 swap. All I have left is to wire up the gauges. I'm going with aftermarket auto meter. Does anyone know how to wire up the speedometer? There's 3 wires going to the sending unit. Orange‚ white & orange and blue & black. They all run to the ECM plug‚ I'm not using the ecm. And the orange & white wire also runs to the gauge cluster plug. Does anyone know how to make it work?
87TPIYJ 03-12-2014 11:05 AM
What kind of VSS do you have electronic or mechanical? Are you running efi that will need a VSS input? If you have a electronic VSS do you know the Pulse Per Revolution?
Why J? 03-12-2014 04:17 PM
From the VSS:
Orange is 8v supply from the ECU.
Black w/ blue strip is ground.
Orange w/ white stripe is signal wire back to ECU and the speedo.
You can wire the orange w/ stripe directly to the speedo and 12v from a switched power source to the orange and the speedo will work correctly.
mason_128 03-13-2014 09:26 PM
Thanks a lot for the help.
AbAngler 03-14-2014 09:44 AM
I'm going to save you a whole lot of time and frustration. Seriously take a look at the newer GPS speedos. If you have already purchased an electronic Autometer speedo, there is a new GPS module that just hooks up to the guage. http://www.autometer.com/cat_accesso...l.aspx?vid=234
Took me about 10 minutes to install mine and I'm not a fan of anything electrical.
Might cost a bit more, but its the easy button.
87TPIYJ 03-15-2014 07:32 AM
That is pretty cool. Because I had a 40 tooth tone ring and my ECM wanted to see a 4PPR I had to buy a Dakota sgi-5. Then I set the autometer gauge to 4000PPM (ECM output to gauge).
AbAngler 03-18-2014 03:01 PM
Thats basically what I was facing too. This seemed like a no-brainer. They are apparently getting quite popular with the muscle car crowd as well. When I bought mine, they had sold 4 others that morning. Good product.
The time now is 01:37 PM.
