Jeep Enthusiast Forums banner
yj 30 stronger than tj 30
818 views 9 replies 6 participants last post by  phlex234
#1 ·
I have a 94 wrangler with a high pinion 30 in front. Are the 30s in a tj not high pinion? Are they not as strong?
#3 ·
so could you switch the shafts from a TJ into a YJ?
#6 ·
so does that mean no, 4 wheel drive?
#8 ·
NAILER341 said:
it means your driveshaft will always spin like the tj does ;)
what are the pros and cons of that
#9 ·
You'll be in the same position early 4x4er's were, before Warn hubs.
Your entire front driveline will be turning always.
Look for 2-3 mpg loss. Wear on the u-joints, front. Some loss of power and maybe some wear on the front tires.
The wear and drag on the TJs isn't as bad as it was with early Jeeps and PowerWagons; but it's there. My TJ daily driver...when I was shifted to a job involving a lot of highway travel, I yanked the front prop shaft. Warn hubs for the TJ are available but a low production item and $1000.
I could feel the difference. Trouble is it was a PITA to take out AND PUT IN because of the skidplate.
#10 ·
that doesnt sound like its worth it
Top
