YJ with 3 inch lift and 35s - JeepForum.com
post #1 of 5 Old 08-19-2011, 11:39 AM Thread Starter
lost in mud
Any luck one have pictures? I plan on staying sua and have the bds 2" with 1" shackles. Plans are rear tj flares and the t&t 4.5" tube fenders in front and put on 1" body lift as well
lost in mud is offline
post #2 of 5 Old 08-19-2011, 11:56 AM
Alfons
In my opinion you'd be low on the rear unless you cut out a piece of the front of each rear wheel well and then you'd need to reposition the roll bar mounting. I have 4.5" suspension lift and 2" body lift with 35" wheels and if the springs were softer, the rear tires would hit the front, bottom corner of the rear wheel well. The other option if to move the rear axle to the back by a few inches to center the wheel in the well - then you'd have enough space.
Alfons is offline
post #3 of 5 Old 08-19-2011, 12:26 PM
dtn8tr
Sounds like time for Waggy springs and SYE!!!
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #4 of 5 Old 08-19-2011, 12:33 PM Thread Starter
lost in mud
I have sye and cv shaft already...I was going to go soa but have been thinking run that setup for about a year then go soa...I have an 8.8 and d30 with 4.88s and lock rites in them in my garage right now set up for either soa or sua. My problem is the 3 speed auto and the gears for driving on the street. What I was thinking was run sua then in about a year either put in a hp44 in front or step up to tons at that point.
post #5 of 5 Old 08-19-2011, 12:54 PM
dtn8tr
Then put in a 4:1 Terra Low and stretch it with the waggy springs...you would have to get a new ds though. Just don't tell the wife!
dtn8tr is offline
Two inch body lift= 2 Inch motor mount lift? TOLjeep TJ Wrangler Technical Forum 12 10-01-2011 09:36 AM
2 inch spacer lift vs 4 inch suspension lift and Death Wobble BadKarma1701 TJ Wrangler Technical Forum 37 03-10-2011 07:00 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 06:38 PM
Right rear tire extends inch farther out than left after 2 inch lift. blang158 TJ Wrangler Technical Forum 9 07-05-2006 12:15 PM
1.5 inch spacer and i inch body lift is this a good lift? magnum629 TJ Wrangler Technical Forum 7 02-11-2006 10:16 AM
