Yj 2.5 running super rich - Page 3 - JeepForum.com
post #31 of 41 Old 09-01-2011, 10:27 PM
Xpress
My temperature sensor is on the intake manifold, pointing outward and on the side. Kinda hard to reach, but time to break out your multi-meter and measure it on the OHM setting with your engine at running temp.
All about that unibody life.
Xpress is offline
post #32 of 41 Old 09-02-2011, 04:38 AM Thread Starter
Sawicki4wd
Okay thanks ill check back and tell you what it reads.
Sawicki4wd is offline
post #33 of 41 Old 09-02-2011, 06:34 AM
Que89YJ
Sorry its different for the tbi jeeps. I will post up a pic in a little bit. The mpfi have it in the front not ours.
Que89YJ is offline
post #34 of 41 Old 09-02-2011, 06:46 AM Thread Starter
Sawicki4wd
Well I had a nice 2 mile walk to work today. I put 10.5 gallons in the jeep and got 62 miles so I need to fix this. I can't afford to drive like this not at 3.50 a gallon.
post #35 of 41 Old 09-02-2011, 09:48 AM
Que89YJ
Tried this to get you going. Disconnect o2 and the temp sensor to put it into the default calibration 1 at a time and drive it for a few miles and see if it's better
Que89YJ is offline
post #36 of 41 Old 09-02-2011, 12:41 PM Thread Starter
Sawicki4wd
I'll try that. Thanks if it works i owe you a 6 pack
post #37 of 41 Old 09-02-2011, 12:43 PM Thread Starter
Sawicki4wd
So disconnect both or just one.
post #38 of 41 Old 09-02-2011, 01:06 PM
Que89YJ
Do them both. You are going to put it into open loop. It should get you 14 mpg unless you have a fuel pressure or injector issue.
Que89YJ is offline
post #39 of 41 Old 09-02-2011, 01:17 PM Thread Starter
Sawicki4wd
Sounds great to me. My injector was just cleaned
post #40 of 41 Old 09-06-2011, 02:58 PM
Que89YJ
How is it running? Did it make any difference?
Que89YJ is offline
post #41 of 41 Old 09-06-2011, 11:37 PM Thread Starter
Sawicki4wd
I'm not sure yet. I Filled my tank Friday. Then my egr patch blew so until I can find a bolt to fit in the hole I dont wanna drive it. I'll be fixing it tomorrow or Friday so I'll let you know
