Yj 2.5 running super rich - Page 2 - JeepForum.com
post #16 of 41 Old 08-30-2011, 07:28 AM Thread Starter
Sawicki4wd
Disconnect postive touch it to negative turn key to run turn lights on then off right
Sawicki4wd is offline
post #17 of 41 Old 08-30-2011, 09:28 AM
oldtime_ironman
Don't even have to do all that. I just disconnect the positive and touch it to the negative and let it sit a few minutes while I do other things. Hook it back up, and all done!
oldtime_ironman is offline
post #18 of 41 Old 08-30-2011, 09:43 AM
bharris68
Daily Driver
Have you checked the fuel return line as was suggested earlier? If you replaced your tank check to make sure it's not pinched off which would prevent fuel return.
Also - put a fuel pressure gauge on it and assure you're in the correct range
bharris68 is offline
post #19 of 41 Old 08-30-2011, 12:25 PM Thread Starter
Sawicki4wd
What line is the return line. I'm guessing one of the smaller lines
post #20 of 41 Old 08-30-2011, 12:47 PM Thread Starter
Sawicki4wd
post #21 of 41 Old 08-30-2011, 08:29 PM Thread Starter
Sawicki4wd
Well apparently I still had an exhaust leak so I fixed that and it quieted down a lot. I'm not sure if it helped running rich yet but I'll let you know
post #22 of 41 Old 08-31-2011, 09:44 PM Thread Starter
Sawicki4wd
Well no changes. Im still running super rich. I went from getting 190 miles to a tank to about 105 miles a tank. It's not the o2 sensor. And I changed and gaped the plugs. Could it be timing. Its weird because it happened when I Swaped my tranny.
post #23 of 41 Old 09-01-2011, 05:08 AM
Que89YJ
Did you reset the battery? Also, you have an EGR that can act like a leak. They are a Pita on ours. At least temporarily try flanging off the EGR or replacing it. I am sure that its a leak causing it to lean out if the O2 is making it run rich.
Que89YJ is offline
post #24 of 41 Old 09-01-2011, 07:57 AM Thread Starter
Sawicki4wd
I did reset the ecu and Blocked off the egr. Im wondering of it could be an vacuum leak. Does anyone have a vacuum diagram for it
post #25 of 41 Old 09-01-2011, 08:07 AM
bharris68
Daily Driver
While not a professional mechanic - it looks like you're thrashing about hoping that any activity or change may "be right" and will stop the problem.
In one of your original posts you noted that you replaced the rotted gas tank - start with the fuel lines, fuel pump, etc. and check them with a pressure gague and check to be sure your return line is not blocked.
If you've blocked off the EGR and made other changes, then you're probably fighting a multiple front war and isolating the problem will only become increasingly difficult until and unless you eliminate one variable at a time - not introduce more Slow down and do one thing at a time. We're here to help - just try to slow down a bit!
post #26 of 41 Old 09-01-2011, 08:48 AM
Que89YJ
I went back through the post. Did you figure out where the 3 tubed vacuum lines went to?
Que89YJ is offline
post #27 of 41 Old 09-01-2011, 10:17 AM
notmyj
Check the coolant temp sensor (the one with two wires going to it). Check it with an ohm meter to read the resistance. I had a similar problem turns out the CTS was causing it. You see, when the engine is running in open loop, it is not paying attention to what the o2 sensor is doing. The only time the o2 sensor will have any effect on the fuel trim is during closed loop. In order for the jeep to go into closed loop, the ecm needs to see coolant temp come up to operating temp, o2 sensor light off (the point that the o2 sensor gets hot enough to make voltage), etc. Until all the requirements are met the computer will run a preset fuel trim based on throttle position, coolant temp, and manifold absolute pressure.
Heres where a faulty CTS comes in. When the CTS fails, it reads really high resistance. This is interpreted by ecm as cold. Really cold. When mine went bad it was telling the computer it was -70*. When its cold, the engine needs more fuel to run. So the ecm starts dumping fuel trying to keep what it thinks is a freezing engine running. Furthermore, since the CTS always reports that its cold, and the ecm never sees operating temp, it will never go into closed loop and read the o2 sensor.
Before you go replacing it, check it with a multimeter. Check the pins in the conecter to make sure there is no corrosion. Use the table below to check the resistance for the temp.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #28 of 41 Old 09-01-2011, 07:59 PM Thread Starter
Sawicki4wd
The cts is where. I can't figure what sensor it is
post #29 of 41 Old 09-01-2011, 09:25 PM
Que89YJ
Its in the front by the thermostat housing.
Que89YJ is offline
post #30 of 41 Old 09-01-2011, 10:03 PM Thread Starter
Sawicki4wd
Okay and yeah it went behind the engine head. Never expected it to go there
