yj 2.5 freeze plug under bellhousing advice - Page 3 - JeepForum.com
post #31 of 45 Old 01-16-2013, 07:25 PM Thread Starter
ldso
Jeep Powertrain Superiority
By using Muncie transmissions
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #32 of 45 Old 08-02-2013, 03:47 PM
stanHetrick
Guys,
I have a '91 YJ BUT 4.0 with Automatic Trans.
Where is the water coming from is my problem too. I'm kinda a newbe and just want to get it running (and go to Pismo Beach yet this summer
After an initial air release much like a tea pot, water has been gushing out of the back of the engine, probably out of the bell housing. Nothing else is wet. Not the heater-I connectetd heater hoses. Radiator is newish (~3 yrs) since one of my sons dinged up the front...
Q? What is different for 4.0 Automatic?
- Does the torque converter NEED to come off to replace the freeze plug(s)?
- If the drive shaft is removed, can everything slide back a few inches - then right back in???
- ie. Does the T-case really NEED to be seperated for only the freeze plug(s)
stanHetrick is offline
post #33 of 45 Old 08-02-2013, 08:56 PM
Opihi59
from here it gets rough
Opihi59's Avatar
If you're leaking water from the back of your engine, you have 3 freeze plugs back there in the 4.0. One is on the back of the head, the other 2 are behind the flywheel. You will need to pull the trans to replace them. Whether or not you decide to separate the transfer case from the back of the trans or not, it is just one helluva lot easier to deal with the trans alone. It is hard to pull the trans back far enough to get a swing on your hammer/driver to reinstall the new plugs though, so you are likely going to have to get your trans on the ground. To replace the one in the rear of the cylinder head, you can drop the back of your engine down/jack up the front of the engine so that you can access this plug and drive in a new one. There isn't enough room to pull back the trans to get a swing as the bell will hit the tunnel before you get enough clearance. Likely one of these 3 freeze plugs is to blame, just replace all 3 of them. There is another small "freeze plug" back there, but I don't think it goes into the water jacket. Someone will know and fill us all in. Or I'll find out more and edit this post.
Edit--yeah, the small plug on the back of the 4.0 is over the oil gallery/end of the camshaft. But you'll be able to see which one is leaking when you get back there, replace all of them you can get to, if one is going, the others are likely to as well soon enough. They do make Brass freeze plugs.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #34 of 45 Old 08-02-2013, 09:14 PM
n9oig
The 3 rd freeze plus in the rear of the block is the camshaft end it doesn't go into a water jacket
88 Jeep Wrangler
95 Jeep Wrangler
SE Wisconsin
n9oig is offline
post #35 of 45 Old 08-05-2013, 08:54 AM
stanHetrick
Thanks for the input! Sooo... I will plan to Drop tranny instead of Lifting engine, and take off the T-case first.
This will be the project for next weekend! Then still 2 wkends left for Oceans Dunes at Pismo Beach!!
post #36 of 45 Old 08-07-2013, 09:57 PM Thread Starter
ldso
Heck yeah enjoy the dunes man! I got to drive mine on the beach in Salvo in the Outer Banks Very cool stuff. Saw some great Jeeps and trucks out on the sand too.
Here is how mine looks tonight:
ldso is offline
post #37 of 45 Old 08-08-2013, 11:54 AM
stanHetrick
Update!
Last night I got home with some light left (and other projects complete
A neighbor ['54 CJ project] happened by and helped with flashlight and mirror.
The HEAD freeze plug is the one leaking. Not inside the bell housing!!!
Looking for the path of least resistance-Not pulling the engine or dropping the tranny- after looking at how to get room by loosening the motor mounts and tipping everything he said 'why not cut a hole in the firewall????' -SO-
Q? Can you think of a good reason why NOT to cut a hole under the AC to get at the freeze plug?? And then make a cover for it…
post #38 of 45 Old 08-08-2013, 12:25 PM
n9oig
I think I would pull the motor your going to have the coolant drained already pull the accessories and pluck the motor its only a 2.5
88 Jeep Wrangler
95 Jeep Wrangler
SE Wisconsin
n9oig is offline
post #39 of 45 Old 08-08-2013, 12:45 PM
Opihi59
Opihi59's Avatar
Nothing wrong with cutting a hole thru the firewall for access to something, then covering it with a plate. However, you may find that this is more difficult than you think. The back of the head is higher up the firewall than you think, and again, it will be tough to get enough room to swing a hammer to drive in the new plug, or to remove the other one. It could be possible that you could pull the skid plate and lower the trans/t-case which will tip the back of the engine significantly downward (and also the front of the engine upward, so make sure nothing gets munched up-wires, radiator, hoses) and this may allow you to cut the hole lower on the firewall and perhaps encompass some of the top of the tunnel. Before you start to cut, do the lowering part and see if you can get a swing in there; having the under dash AC unit makes this approach significantly more difficult of course.
For me, I'd pull the trans and if I couldn't reach still with tipping, the motor would come out. It really isn't that big of a job, it just has some painful components. Generally freeze plugs start leaking because they have rusted thru from the inside out, and if one went, what is the condition of the rest of them? You didn't just get one unit from the island of misfit freezeplugs, they're all likely to wear out over a similar timespan and they're all the same age suffering from the same conditions. Get brass freeze plugs as a set, replace them all unless you perhaps relish doing the job again for another painful to reach freeze plug. Just my thoughts.
Opihi59 is offline
post #40 of 45 Old 08-15-2013, 10:25 PM
stanHetrick
Quick update: All better, but I cheated
As mostly a newby, I spent all Friday under there cleaning out oily sand. Did some easy stuff like pull the starter (that I put on w/in the last 6 mths) torque cover and drive shafts.
Then I started looking at rusted parts and couldn’t really find all the bolts. So Saturday I threw on the skid plate and pulled it to a shop. Got it back yesterday. Was afraid I wouldn’t be able to get it back together. Except for being $550 lighter, all’s well.
Thanks for the help and encouragement though. I will need more shortly as I’m hoping to put in a SOA lift this winter and get on 35’s! Rubicon next yr?!
post #41 of 45 Old 08-27-2013, 02:27 PM
stanHetrick
New Revised Update: 
A week ago I picked up YJ from shop. Started great, as it had since new starter & battery within 6 mths.
Drove & shifted fine, but a little cross threaded. Ie D was almost N; N was almost R; and R was close to P.
Then next day it drifted into Reverse from park (almost taking off the passenger door). A day or two later it wouldn’t start at all. No sound at all. Jumped it – still no sound at all, not just the battery.
I assumed it was a linkage adjust problem not actually being in Park which is why it was not turning over.
I towed it back to said mechanic. He replaced the Neutral kill switch but now is blaming the non-start on metal shavings in the transmission pan…
Now it is 23 yrs old, but that is not the reason not to start. I feel they screwed something up. Know it and are running from it.
Towing it home tonight. What questions should I ask him when I pick it up? I probably could/should rebuild the tranas, but that’s not the reason it won’t strart. Any thoughts are welcomed.
post #42 of 45 Old 08-29-2013, 02:51 PM
stanHetrick
Towed it home. This cable is obviously loose. It's not really coming from the column shifter. Are there any pics around of what it is suposed to look like???
post #43 of 45 Old 10-12-2015, 08:13 AM
Jeepsr4me
What you did will work..
BUt you had everything out of way to install the correct freeze plugs so what you did makes no sense.
And you replied to a 2 year old post.
For a trail fix or for repairs to keep a daily driver going or someone that lacks space to fix or tools this repair is OK.
But when you already got the dang intake and exhaust out FIX IT RIGHT... Not hard to drive in real plugs...
Jeepsr4me is offline
post #44 of 45 Old 10-13-2015, 01:31 AM
RockCzar
1997 XJ Cherokee
I asked my mechanic about the brass installation, however he was concerned with clearance issues regarding getting them to seat properly to avoid having to tear everything down again if they happened to leak.
Fingers crossed the rear plug is OK and stays that way for awhile 'cause it sounds like a major hassle and can get probably get "labor" costly.
Regarding 2yr old post...Unfortunately, I was seeking answers and this forum has conflicting info regarding this issue (and probably many others) so I posted to hopefully save the next poor soul the hassle of wading through all the crap to get a straight-forward solution...not to mention the fact that 2yrs ago I didn't have this Jeep or this issue.
..____________
//__l__l__,\____\,____
l_--\__l__l_/--|lllll|
_( )_)=o=( )_)=o=( )_)
RockCzar is offline
post #45 of 45 Old 10-13-2015, 08:10 AM
Jeepsr4me
Again a piss poor repair done at a time when doing it right was EASY...
Those plugs are like hoses.. They get old and crack and will leak.
A mech that thinks like the one you got needs to be kicked to the curve. Seating brass freeze plugs is not that hard.. Almost to damn easy...
heat from the exhaust will work on the plugs and destroy them at a rapid rate.
