YJ 02 sensor help - JeepForum.com
post #1 of 8 Old 04-06-2013, 06:00 PM Thread Starter
drewyj
YJ 02 sensor help
hey everyone, im new to the thread. i own a 94 yj.
so my engine mount bracket broke the other day, so i went and bought
M.O.R.E (mt off road) engine mount bracket that uses 8 holes instead of 3.
well i have a borla header on and the mount wont fit with the header. so i bought a new OEM header, the problem is i have a stright pipe back and if
i put the OEM header on and wield the exhaust i already have onto it i wont have an 02 sensor... Is this a major problem?
i dont care about inspection/ check engine light.. just motor issues
thanks everyone!
drewyj is offline
post #2 of 8 Old 04-06-2013, 06:42 PM
Reno72
I would rather keep the headers and go with oem motor mounts. Yes you need the o2 unless you override the computer sensors that do adjustments by the o2 readings.
Reno72 is offline
post #3 of 8 Old 04-06-2013, 09:53 PM Thread Starter
drewyj
the problem with keeping the 3 is that 2 of the bolts are stuck inside the block, they snapped off inside of it. ( all 3 bolts did)
but i got one out and my easy out broke off in the other 2... =/
so i dont really have a choice to keep the 3. and i already bought the 300$ mounts
drewyj is offline
post #4 of 8 Old 04-06-2013, 11:17 PM
bigsquat
cant you drill a hole and add a threaded bung to install the o2 sensor. your computer needs the input to make it run properly
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #5 of 8 Old 04-07-2013, 06:54 AM
Que89YJ
The O2 sensor is the primary input for controlling air fuel. Your fuel economy will go to crap. Did you try pulling the fender to get at the bolts that broke?
Que89YJ is offline
post #6 of 8 Old 04-07-2013, 10:43 AM Thread Starter
drewyj
ive tried everything, on both bolts the eassy out snapped flush with the block, so my only option would be to drill
the whole bolt/easy out,out and re thread the hole
drewyj is offline
post #7 of 8 Old 04-07-2013, 12:04 PM
Que89YJ
You need the sensor.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #8 of 8 Old 04-07-2013, 03:05 PM
bigsquat
just relocate the sensor
bigsquat is offline
