Yet ANOTHER transfer case thread! Hah! - JeepForum.com
post #1 of 8 Old 05-31-2013, 11:10 AM Thread Starter
Tommypro-photo
Hi everyone, I'm Tommy and new to this forum. Seems I'm having some issues with my NP-231 Tcase that I could use some input on. I'm VERY mechanical and intend to tackle this project on my own... so here's what's up:
My problem is with 4WD engagement and operation. Basically the Tcase linkage moves as it should in all positions and I believe it is properly adjusted. Low range and high range both work properly but the 4WD doesn't always engage when it should be! When I bring it down to 4-low and enter the mud/sand slowly... most of the time only the back tires turn. If I slightly "blip the throttle", there will be a tiny bit of grind and the front tires will start to grab. This usually works in 1st or second gear in low range blipping just off idle. If I try in any higher gear with anymore throttle... she just grinds. If I enter a hole nose down, it rarely will engage at all. If I'm exiting nose up, it is much more prone to give me 4WD. It almost NEVER gives me 4WD in reverse. The problem is definitely in the case and NOT related to the front disco. Sometimes under deceleration it will pop out of 4WD on the trails with a small bang/pop noise.
So there it is! Any ideas from the experts here? I suspect a fork issue.... what's your thoughts?
Thanks!!
Tommy
Tommypro-photo is offline
post #2 of 8 Old 05-31-2013, 11:32 AM
dadstoy
Sounds to me like your CAD is acting up. It works off of a vaccum switch located in your tcase. It could be a vaccum leak, CAD on its way out, or a bad switch in the tcase.
dadstoy is offline
post #3 of 8 Old 05-31-2013, 11:58 AM
DirtKar
I pledge allegiance.
DirtKar's Avatar
First off, welcome to the forum!
What is it that makes you so sure that your problem isn't in the disconnect? From our description it sounds like a fair candidate. When I rebuilt mine (TC) the pads were worn on the fork and it didn't cause the issues you describe. Why not just lock the fork over in your cad and see if your troubles go away. Much easier than dealing with a potentially unnecessary TC rebuild.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #4 of 8 Old 05-31-2013, 12:00 PM
Que89YJ
Que89YJ is online now
post #5 of 8 Old 05-31-2013, 12:24 PM
jeepster93
jeepster93's Avatar
X4 on checking the cad.
jeepster93 is online now
post #6 of 8 Old 05-31-2013, 12:28 PM
flcracker
didn't look at teh links provided but if you want to give yourself some peace of mind about the TC, put it in 4wd and have someone look to see if the front driveshaft turns when you move. My understanding (right or wrong) is that if you are in 4wd, it will turn, if not, it won't....
That being said, put me down for x4 on the CAD....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #7 of 8 Old 05-31-2013, 01:09 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Some good reading for ya
http://www.jeepforum.com/forum/f12/t...80/?highlight=
Anticanman is offline
post #8 of 8 Old 06-01-2013, 04:27 AM Thread Starter
Tommypro-photo
Thanks everyone for the responses. The fork in the CAD up front has been locked via moving the snap rings. I have tried everything relating to that and it works with vacuum switch, but I have slid the fork over anyway. nylon pads are also good on the CAD fork.
